Old 04-27-2011, 02:05 PM   #21
Marc LaBrecque
Liked 431 Times in 114 Posts
Wink Re: Header coatings - Part Two
Ya know Jack , even with the quality coating job you got on the tubes at the rate it's taken to get the motor done they may rust again ..... Just pay the man will ya ????
Marc LaBrecque is online now   Reply With Quote
Old 04-27-2011, 04:03 PM   #22
Darrin Christen
Darrin Christen's Avatar
Thumbs up Re: Header coatings - Part Two
Darrin - Stainless headers offer some advantages but the $3,000 price tag scared me off - and I can buy a good broom at Home Depot for under ten bucks ..................
Yes, I understand the cost issue, thats why I built them myself. The broom is not a problem, but Home Depot or Walmart don't carry new headers when your hundreds of miles from home and the headers are falling apart! BTW your headers look great with the new coating, nice job.
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 04-27-2011, 04:42 PM   #23
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Header coatings - Part Two
Do you guys just not pay attention to stuff between races, or do you just run it till it quits? I don't ever remember having headers "fall apart" at the races.
The tubes look great, Jack!
Old 04-27-2011, 05:37 PM   #24
Darrin Christen
Smile Re: Header coatings - Part Two
Ok, so maybe I exaggerated a little with the "falling apart" statement. I've had a collector almost fall off due to the tabs on the primary tubes breaking off due to rust from the inside, not very noticable when the ceramic coating on the outside looked fine.
Old 04-27-2011, 06:55 PM   #25
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Your downturns are pointed inward not down....or at least that is how it looks to me....
Rich Biebel
S/C 1479
Stock 147R
Old 04-27-2011, 07:54 PM   #26
Tom Goldman
Tom Goldman's Avatar
Liked 882 Times in 236 Posts
The collectors are are on the wrong sides Rich , Kinda like tubes 2 and 4 .
Thats why Jack pays the bills and I do the work!
Old 04-27-2011, 08:16 PM   #27
Rich Biebel
That was my guess Tom.......
Did you tig weld the turndowns on ? I have never had much luck tig welding on previously coated headers.....Tried it on my old dragster....no matter how much I cleaned the area it was not good. Mig welding them was a snap and a little ceramic paint and they looked fine....
Rich Biebel
S/C 1479
Stock 147R
Old 04-28-2011, 07:54 AM   #28
Rich - You are correct -- and that's what happens when you hurry - but they looked good for the picture .And by the time they get on the car I'll point them in the right direction or I'll never hear the end of it .Sorry I can't tell you about the welding stuff - that's Tommy's department .................
Old 04-28-2011, 08:26 AM   #29
Tom Goldman
Rich, I tig them.
I use a 2" Rolock scotchbrite wheel to remove the heavy coating on the area being welded.
I've found cranking up the gas flow ,and using ER70-6 wire instead of the more common 70-2 works to give a clean weld on a coated tube.
