#11 |
any new cj ford or DP will be just fine tighten them lugs
#12 | |
Banned
Liked 235 Times in 110 Posts
#13 |
Liked 140 Times in 51 Posts
#14 | |
Kevin |
#15 |
Liked 100 Times in 45 Posts
Roger,stop giving our secrets away.:<):<)
Former NHRA #1945 Former IHRA #1945 T/SA |
#16 |
'68-'70 AMC AMX 2-seat 97" wheelbase. Will run fast in Stock or Super Stock on 9" slicks with Calvert rear springs and bars. I went 10.50's in D/S with a 390 and loaded a "fair" SS 390 and a steeper rear gear. Went 10.00 in SS/H. The 290, 390 (either 1968-1969 or 1970 (different specs) and '70 360
will all under by a significant margin with the 290 as Roger mentioned probably the best to build (and cheapest). But you probably want a belly button car... ![]()
Jeff Lee 7494 D/S '70 AMX |
#17 |
Liked 8 Times in 7 Posts
jeff, are you aware of any "approved" 290 pistons? 2bbl or 4bbl?
i'm not.... that's why i've got one (from ED F) that's gonna get sent in (to a mfgr) one of these days, probably this fall |
#18 |
Tom,
Check with Hemmy Adkins or Garrett Ghezzi (SS/MA from Joliet, IL) for NHRA piston. Dwight Southerland played around with one on a dyno also. |
#19 |
Hi Roger
Back in the late 70s and early 80s I ran a 69 AMX in NHRA Super Stock with a 390 engine. Not wanting to move the rear springs or alter the wheel tubs the only tire that would fit was a 9 in tire. I have thought about geting another AMX but I would not want to alter the rear of the car. What if any thing could be done to use a bigger tire with the stock length rear end and no alteration to the spring location and the wheel tubs? Thanks Allen |
#20 | |
