Old 06-09-2011, 08:53 PM   #31
bob3240
Liked 16 Times in 5 Posts
Default Re: car stumbles in the air!
do you have the black tape on the secondary metering rod slots?
bob3240 is offline   Reply With Quote
Old 06-09-2011, 10:14 PM   #32
TinSoldier 3215
Liked 6 Times in 5 Posts
Bob, No.
TinSoldier 3215 is offline   Reply With Quote
Old 06-10-2011, 02:40 PM   #33
John Musial
Liked 51 Times in 3 Posts
jonesracing you have a PM
John Musial is offline   Reply With Quote
Old 06-10-2011, 07:16 PM   #34
Liked 1,831 Times in 415 Posts
Got this from a friend and fellow racer, a really good racer. Check the fuel pump. There was a car with this exact problem, and what was happening was that under G's from the launch, the armature of the fuel pump would move and short out. It did not show on the fuel pressure gauge. They fought this problem all year, and a new fuel pump fixed the car for the last time trial at the last race of the season.
Old 06-14-2011, 08:28 AM   #35
Rusty Davenport
Liked 101 Times in 27 Posts
Arrow Re: car stumbles in the air!
This is for real......check the main wiring terminal for loose connections...check them with a wrench---not your hand......when I let go of the tranny brake the connection would momentarily lose connection then reconnect when it hit the ground off the wheelstand.......do not underestimate this happening, do not trust checking with your hand I say again....I felt stupid when I started replacing parts and found out a nut needed WRENCH TIGHTNESS.
Rusty Davenport is offline   Reply With Quote
Old 06-15-2011, 10:44 AM   #36
Ed Wright
Ed Wright's Avatar
Originally Posted by rusty davenport View Post
this is for real......check the main wiring terminal for loose connections...check them with a wrench---not your hand......when i let go of the tranny brake the connection would momentarily lose connection then reconnect when it hit the ground off the wheelstand.......do not underestimate this happening, do not trust checking with your hand i say again....i felt stupid when i started replacing parts and found out a nut needed wrench tightness.
x2!!
Ed Wright 4156 SS/JA
Old 06-18-2011, 10:00 AM   #37
TinSoldier 3215
If the rain stays away we are going to try things out tonight!!
Old 06-19-2011, 04:32 AM   #38
Aaron Keown
Aaron Keown's Avatar
First thing you should probably do is see if a fellow racer with a similiar combo will let you borrow his carb. for one pass so that you can make sure that is what is really causing the problem before you try chasing down lose wires or any other number of things that could be causing this.Good luck ,you'll find it.
Aaron Keown is offline   Reply With Quote
Old 06-25-2011, 09:59 AM   #39
TinSoldier 3215
Well after 3 weeks of Bad Luck we went to the track and found the issue. Thanks for all your guys help. It turn out to be the button!!!
Old 06-25-2011, 12:54 PM   #40
junior barns
Liked 20 Times in 14 Posts
what button?
junior barns is offline   Reply With Quote
