#31 |
Liked 13 Times in 3 Posts
Personally, I don't like the drive by wire. That being said, I think it is legal
Chuck |
#32 | |
I have a Bluetooth interface that hooks up to the OBDII port under the dash. http://cgi.ebay.com/V-1-4-obd2-elm32...item2a10cdce66
#33 | |
Ed Wright 4156 SS/JA |
#34 | |
Guest
Posts: n/a
I called brad Charlie cause they look similar, sorry Brad.. :/ It's been awhile since I've seen Charlie. A little calculus will tell is what's really happening with the throttle manipulations going on, right? Thank you Newton. ![]() |
#35 |
Ed....Bluetooth, WI-FI, 802.11 are all available to access data and monitor a vehicles functions with the proper interfaces and apps that are also available,with the micro electronics some of these are small enough to integrate into an ignition box or an ECU.....the technology has been out there for years (F1 has been able to do this for a long time but they aren't supposed to use it, same with INDY cars....monitoring is OK,tuning on the fly is not even though they can).....auto-tuning and or self calibration to a preset ET (once set) is pretty easily done for someone intent on doing it.....
D L Rambo..... |
#36 |
Liked 10,676 Times in 2,220 Posts
Chuck of C&W try looking for a program that looks very similar to cruise control. You know you tell the computer how fast to run and the computer adjust throttle position, fuel delivery, and timing to trace a run.
Remember F1 had to pass a rule to have the driver shift the transmission. Most if not all things are possible if enough money is spent in the right place. |
#37 | |
#38 |
Liked 4 Times in 2 Posts
Get over it Larry....I could cheat if I had a pink Mopar...too..lol
Drive by wire is not desirable...for us anyway....it's just the way the new cars come.....if you run a factory ECU....you get drive by wire....if not...you use a cable....end of story....ask Bo....lol |
#39 |
Liked 370 Times in 101 Posts
Charley, I'm confused, my 93 Mustang Cobra H/S car is nearing completion, and where should I set the throttle to prevent being blown off the track because I don't have a supercharger ? I'm thinking with all that horsepower that you found on the dyno, that if you get bumped into H/S, all my efforts will be for naught.!!!, and how would would I feel then. LOL!!!
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
#40 | |
Liked 70 Times in 29 Posts
I'd set your throttle at 200% if I was you!
Chris Bowman The Mountain State Mustang 1984 Mustang GT350 |
