Old 06-16-2011, 09:51 PM   #11
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
Default Re: Sunoco supreme
Originally Posted by Myron Piatek View Post
Sunoco Purple also seems to be one of the more "stable" fuels. Never had a problem with it in fuel check.
I absolutely agree with that. I`ve had 10 gallons in my stock gas tank all winter and have it pass the first race out. Also curious what some of you are paying for it.
Lane Weber
Old 06-17-2011, 08:46 AM   #12
Chad Rhodes
hell the fastest pass my I/SA camaro has run was on 93 octane pump gas. Have run both C12 and sonoco supreme, don't really see a difference.
Chad Rhodes 2113 I/SA
Old 06-17-2011, 09:45 AM   #13
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
KCIR in Kansas City sells it for $7.50 a gallon. I have not had any problems with passing either.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-22-2011, 08:22 PM   #14
jlstoec
In my 12.8:1 540 I have not seen a difference between Torco, Rockett, or VP. I did give Q16 a go but don' think I got the tune right and didn't see gains.
jlstoec is offline   Reply With Quote
Old 06-22-2011, 09:57 PM   #15
Ed Wright
Ed Wright's Avatar
Chad, I wouldn't put C12 in an engine with no more compression than that. Too much octane can sure slow you down. It burns slower. C11 works well in lower compression engines. Usually need to add 5% or so WOT fuel (top 3 rows of your fuel map.)
Ed Wright 4156 SS/JA
Old 06-23-2011, 11:45 PM   #16
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
purple is $9.00
blue is $10.00
at 2 local tracks in Maryland. I'm ready for E-85 but I'm afraid of my 13.6 CR and short duration cam.
Ron Gusack is offline   Reply With Quote
Old 06-24-2011, 01:53 AM   #17
Pvt Parts
Pvt Parts's Avatar
Not surprising. "Stale" gas usually passes. If you're "close", the problem is getting fresh gas to pass in 80 to 90 degree heat.
Old 06-24-2011, 01:41 PM   #18
njk53
We have been paying $6.58/gallon for Sunoco Standard.
Nelson Kowal
Stock 345
