#11 |
Liked 507 Times in 92 Posts
On the super t-10's the first gear doesn't sit correctly on the cluster, it only meshes about 3/4 of the first gear, you may want to have the gears machined to fit on the cluster better.
Casey Miles 248H Stock? |
#12 |
Liked 66 Times in 29 Posts
A muncie with all Liberty gears would be an improvement over stock
#13 |
Liked 3 Times in 2 Posts
I could go back and run a stock trany (IF) we went back to stock un-ported heads, stock block, rods and crank other wise there aren't enough stock trans parts left to run one of these cars. Back before Jerico came out I would have fresh trany in car, one in the trailer and enough parts to build one at the track and did that on a few ocasions. On second thought forget it I wouldn't go back for any reason I broke two Jericos last year so an auto don't sound all that bad. Just boring.
Jeff Colvert SS/G,F,GT/B 4456 |
#14 | |
Liked 161 Times in 52 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#15 | |
Hope Dad is doing well tell him hi.
#16 |
Liked 307 Times in 103 Posts
Casey,
I've cut low gear to line up with cluster,I have found a 9310 low gear,Thank's Scotty D for the info. Larry, All Liberty has for Muncie or T-10 is a few parts and pieces in storage they have'nt had gear sets for them for a while as far as I know,they do still pro shift them but that is about it on T 10 or muncie. Jeff, You had me concerned there for a minute,I like watching you run. I owned 2 autos my first and last,without a stick it's no fun for me. Turn it loose on high side chip and try to rip shifter off every gear is best stress relief I know. Mike Taylor 3601 |
#17 |
Mike Taylor: There's a Liberty gear set for a Muncie on Ebay now. You are better off with a Super T-10 Liberty though. Once you have straightened out first gear, it should be OK. There is a place called S&K Speed shop on Long Island, the guy there is a guru on Super t-10s. He can make a fully sync trans. shift like butter. Use a soft clutch and it will live a long time.
#18 | |
#19 |
Liked 9 Times in 2 Posts
#20 |
Liked 12 Times in 12 Posts
