#41 |
Liked 7,782 Times in 1,743 Posts
75 262 uses a 1.09 venturi 2g. 76 uses 1.18 venturi carb. 267 uses the big 1.218 venturi dual jet. 1.18 2g flows about 320 cfm, big dual jet about 300 but it is more difficult to make work.
#42 | |
Liked 6 Times in 5 Posts
#43 | |
That one sent me scrambling back to the guide to check it out! While I was there, if you can, enlighten me on the 96 Dakota with the 153 4 cyl. Is that based on the 242? If it is then that puppy at 115 HP could be a kickass W combo.
#44 |
Liked 780 Times in 194 Posts
The 153 may be the 60 degree V6.
#45 |
Engine guide says it's a 4 with same bore size as the 242.
#46 | |
Liked 8 Times in 7 Posts
world of difference in the 150 (2.5l) in a dakota (ohc) and a pushrod 150 in a jeep... the dakota is based on the 2.2 omni with a taller deck height the 150 jeep is a sawed off 232 kinda... |
#47 |
Liked 4 Times in 4 Posts
PT Cruiser with the turbo rated at 180hp which is the same engine as the GT at 220hp except for computer parameters, I'm told.
Same package as the no. qualifier at Indy last year. JimR
Jim Rountree |
#48 |
#49 | |
Liked 20 Times in 3 Posts
#50 |
Kevin - Yes I do remember. That was one of the tidbits of info I was using in my analysis.
When are you going to race your beast? It cost a bit more than a dime, didn't it! |
