Old 07-03-2011, 09:12 AM   #61
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Some "Dime Rockets" for the 4TH!
Billy -
The Buick is on my list, too! If you consider the 4-bbl version at 240, the same spec engine is listed for 76-79 which gives more options.
Old 07-03-2011, 10:54 AM   #62
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Okay, since I have already let the cat out of the bag on the other thread, I will start with my favorite, the '76 or '77 Camaro, '78 Camaro LT or '78 Firebird Formula, or '79 Camaro Berlinetta with a 305 2-bbl for U/SA. The pluses for this combination and the potential makes it a must look at in my opinion.
If I read this right, a 79 Firebird with a shipping weight of 3358 LBS would have a weight break of 18.66 and fall into R/SA. The index is 14.05 ?
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 07-03-2011, 12:03 PM   #63
Frank Castros
Liked 2,768 Times in 980 Posts
This thread is what class racing is all about. Way cool.
Old 07-03-2011, 12:03 PM   #64
Liked 5,153 Times in 1,967 Posts
You need a 78 (Formula) with the 2GC (round) carb. Natural T car.
I'll get back on the Buick. I have to look at some specs.
First problem is a cheap set of headers...
Second is finding a torque plate....
Old 07-03-2011, 12:04 PM   #65
Dwight Southerland
'78 Firebird Formula has a 19.18 break, so it is a natural T car and will fit U with weight.
Old 07-03-2011, 02:11 PM   #66
SStockDart
SStockDart's Avatar
Liked 606 Times in 213 Posts
Jeep Comanche (pick up) with 4.0 inline 6 and fuel injection (1990 I think) fits P-Q-R. I think someone has one on the east coast. Cheap parts. Since many of the Cherokees (same frame) are used to "off road" race in the Southwest deserts so parts are plentuful.
Old 07-03-2011, 04:20 PM   #67
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
How about using a std bore cast rebuilder second ring in a .030 over application? Goes along for the ride and makes you legal.. Guilty!
Isn`t there a trick similar to this with the oil ring?
Lane Weber
Old 07-03-2011, 04:49 PM   #68
Chris DeGidio
Chris DeGidio's Avatar
96-99 Jeep Grand Cherokee 242/190-175/170 MPI
2WD of course! bulletins that cover intake systems and the cylinder head that would possibly be even better than the current listings.
This is an R, T, or U car depending on year and model and you could even squeek a 5-speed into the 96 model.
What about the regular 4dr late 90's Cherokee?? Does it fit??
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 07-03-2011, 05:07 PM   #69
Yes, Lane. You can use under size (std, .020 bore ,etc) expanders .
Or you can squeeze each ridge with needle nose pliers and then drag the piston through the cylinder with a fish scale and see what you've got...
Or, 3 Open up the wallet and call Total Seal, Gregg Luneack or someone else that's competent.
Old 07-03-2011, 05:13 PM   #70
Dwight Southerland
Cherokees are not in the Class Guide. Grand Cherokees are starting in 1996. The 1999 Grand Cherokee and the 2001 and up Dakotas with the 287 (4.7 V8) are also a good choice, just don't believe that motor can be raced for cheap.
