Old 07-23-2011, 07:09 AM   #11
3pedals
Default Re: Cal Tracs and Instant Center????
Maybee your right about over thinking it all?
Shocks are DA's on rear. they are mounted in the oem location in front of the axle.
I cant beleive 28x12.5 ET street bias is not enough tire to hook this thing?, but I'll take you guys word for it, my next tire will be a stiff sidewall slick.
Thanks for your input about the top/bottom adjustment hole's effects. I keep thinking that because slow speed video is showing the tires turning before the suspension seperates, that I need the suspension to hit the tire quicker. I guess I have the rest of the season to mess with that, because new tires are not happening untill spring time.
Thanks
Barrett
3pedals is offline   Reply With Quote
Old 07-23-2011, 11:51 AM   #12
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
[QUOTE=
Do you have any input on the original question - does the cal tracs change the effective Instant Center of a leaf spring suspension?[/QUOTE]
CalTracs most definitely change the instant center. The rear attachment point (the one directly under the axle tube), is much lower so that the angle is more acute through the the front attachment point (the one below the spring-eye), in other words, pointing upward.
I have to agree with what Dinsdale said. In back to back testing on two different cars, we found the lower hole on the front mount resulted in less separation between body and wheels, as you would expect from a lower Instant Center. The resulting hit was softer, and that enabled the cars to hook on hot tracks. In better conditions, the upper front hole sometimes resulted in better 60 foot times, but it was not nearly as consistent. These were both automatics.
But what really made it work was finding the right shock setting. Controlling the rate of separation, as you already mentioned, is key, and ADJUSTABLE SHOCKS CAN POINT YOU IN THE RIGHT DIRECTION WITHOUT SPENDING MONEY. Don't assume that it's a harder hit that you need. Try going both directions with the shocks. If a stiffer shock (when extended) improves your 60 foot, then you'll know the IC needs to be lower. If a looser extending shock helps, a higher IC. It's also possible that the shock adjustments alone will be enough.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 07-23-2011, 11:54 AM   #13
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
Hey Barrett,
If my wheel offset will work on your car you can try my slicks for a couple passes...... not 12 ! I know how you like to make laps!! Ha ha
I know Ed doesn't buy it but I still think track prep is better on Saturday as well. Gary
L78 Nova is offline   Reply With Quote
Old 07-23-2011, 01:06 PM   #14
3pedals
Originally Posted by L78 Nova View Post
Hey Barrett,
I would love to take you up on that Gary, I am using 8.5" wheel w/ 3.5" backspacing
Yeah sat is probably the way to go
Tony - thanks for the advice, it makes sense. I will definately mess with the shocks to see if they can lead me in the right direction.
Old 07-23-2011, 11:28 PM   #15
Jeff Lee
Jeff Lee's Avatar
And I saw elsewhere that you had a pair of very old and probably worn out leaf springs. We all understand budgets but there is no "miracle band-aide cure on the cheap" when it comes to a drag race rear suspension.
I would put a pair of M/T 9x29.5 stiff sidewall slicks on it at the same time I put a pair of Calvert Racing rear springs. I'm guessing that would help a ton. Then you can save for a good clutch as offered by either McLeod or Advanced because the clutch and rear suspension are all inter-related. But I would definitely suggest the rear part of the car gets the first rehab.
Jeff Lee 7494 D/S '70 AMX
Old 07-25-2011, 12:45 AM   #16
3pedals
My leafs are new, '68 style multileafs with an extra main leaf added in front of the axle.
I am not looking for miracles Jeff, I am just trying to learn how to build me a working stick car rear suspension.
Do I want antisquat, or no antisquat? what does a stick car want on the "hit" My car does not seperate the suspension at all on the hit, but after the tires spin a few(8-10) revolutions , then it seperates about 1.5" and the front comes up, and the car moves out - kinda makes me think i need to add some antisquat to the initial hit to try to get the tire to bite?
****, this car 60'd 1.60 with frickin drag radials that everyone said DONT work with the stick, now I switch to the Bias, and I'm havin trouble getting theese 28 x 12.5 bias to even run the same 60's.
Old 07-25-2011, 02:22 AM   #17
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Well, I'm far far from being any kind of suspension expert but it seems like your rear springs may be part of the problem. As soon as you have a spring that is trying to control windup and a traction device such as a Cal Trac then you end up with a conflict of interest. I've seen low 10 second cars with just a slapper bar and there are the old Mopar S/S springs that worked well without any help.
All the spring needs to do in a race car is set the ride height. Then the traction device (I.E. Ladder Bar, Cal Trac etc.) along with shock adjustment is tuneable. That's why a coil over setup works as well as it does. My suggestion for the little it's worth is go to a Calvert Mono spring for your car or keep the current ones and ditch your slide a links and clamp the front half of the springs or try a cheap set of slapper bars if you get wheel hop.
The other thing mentioned is a stiff sidewall tire but they don't come in many sizes so you have to do some research on that deal. I run a Goodyear 29x11 and they quit working long before they are worn out because they are a regular sidewall.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 07-25-2011, 06:10 AM   #18
69Cobra
Liked 2 Times in 2 Posts
I think you are excepting the suspension to separate without traction and that's not how it works. The tires have to hook to some degree for the rearend to want to rotate which is what makes the suspension separate. Think if your car was on ice and you dump the clutch. You are not going to get any separation because you have no traction. Put a set of 3056 M/T's which are the 9 x 29.5 stiff sidewall on 10" wheels and you will see a completely different car.
Also, even tho you have 12.5 tires you have them mounted on 8.5" wheels which is not helping you.
Don't forget about the front suspension. The front and rear have to work together.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 07-25-2011, 07:49 AM   #19
james schaechter
Liked 1,436 Times in 299 Posts
Good advice. Make a list and start testing. I am not sure how much you spend to go the track, but I bet it is at least $100.00. (not counting racecar expense) You can waste money going and still have less than desirable results. Skip a few trips to the track until you can get a few of the items mentioned.
Leaf springs are not expensive. If you get the calvert split monos or landrum monos. Sounds like you have a really stiff set up. Sometimes you can find thiis stuff on craigslist, or swap meets too.
Check to make sure you have enough rear shock travel too.
Slicks- make sure that you get a stickshift slick. If you are borrowing a set, more people have automatic cars. I have known many who think it doesn't matter that much.The auto slicks are also a different compound and a softer sidewall. It might be better than what you have, but not enough to learn anything.
The 60 ft improvement could be telling on your stiff suspension. Maybe it took that much to even atytempt to plant the tire. Probably wouldn't do it with those tires and your set up, but it was trying.
I think some of the guys that run those tires also use digital timing control to help. Either a digi 7 or an add on box. If you don't need to run them for any kind of rules, I would bolt a set of MT 3056sts on it as a tire choice on top of the other necessary changes.
Good luck!
James Schaechter 3163 STK
Old 07-25-2011, 07:53 AM   #20
3pedals
The Ice analogy made sense to me, thanks Kris
Thanks for the advice everyone.
