#11 |
Liked 10,822 Times in 2,250 Posts
I think it will be -.857 in stock with all the new cars getting in when it gets down to 1 grade point.
#12 |
Liked 355 Times in 80 Posts
#13 |
Liked 325 Times in 50 Posts
I'm not sure if there will be 180
Jeff Teuton 4022 STK |
#14 |
More CJs & DPs.
Ed Wright 4156 SS/JA |
#15 |
Liked 653 Times in 89 Posts
New technology dominating, how could that be?
STK bump .746 SS bump .712 There are only going to be 6-12 more new cars then last year. And remember three of those fast stocker fords from last INDY are now SS cars.
Charley Downing 3548 STK |
#16 |
I will say it is going to be close to that again this year/....
Danny Waters, Sr / 73 Duster "340" |
#17 |
Ya know Charlie Bob, sometimes there are just things that shouldn't be said. Now I know that you can't help yourself but I sure am glad that you brought up "new technology".
It's amazing how far FFFord has come in their attempt to perfect the internal combustion engine. Let's see 287 cubes, 4 valves per cylinder, overhead cams, port FI, CNC ported heads, big TB, you know the stats now let's compare it to that old warhorse of Stock and SS the 4V 283. You've got a factor of 232 HP and the 283 is 226. WOW! 46 years of "new technology" and FFFords best minds have managed to eke out a big 6 HP! Technology boggles the mind! If I were A FFFord engineer trying to explain that one I'd be embarrassed! BTW Charlie, someone should make sure that the mistake in the guide gets fixed rating your car at 232HP in SS AND Stock before Indy.
#18 |
Your right Billy
Those 40 year old 283 don’t have acid ported heads and intakes, good CP pistons, light cranks, light valves, good rods and better cams. There just like they were in 1966. HA HA.
#19 | |
You should remember what the difference is, you were a "hot rodder" once! HA HA.
#20 |
My 283 don't have all that either and runs about 80 under and that would be about right considering the diff in equipment....probably would not pass nhra cause too stock...
