Liked 244 Times in 26 Posts
Given the rules listed below for a truck pull class, what style engine do you think would be the best?
Classic big block Chevy New style Chevy vortec engine (not sure how different these are from classic big block Chevy Gen 3 Hemi (not sure if cast iron heads available) Big LT-1 or LT-4 Chevy LS style engine (not sure if cast iron heads available) Thanks in advance. I'm just bored this weekend. Chris 13. 485 cubic inch limit. OEM cast iron blocks and heads only. Must fit stock intake. No aluminum heads, any cam. 15. Aluminum intake allowed. No tunnel rams. No sheet metal intakes. One single four barrel carburetor allowed. 16. Headers must point down and back, parallel to the ground. 17. No after market fuel injection systems. 18. Illegal fuels: All forms of nitromethane, nitrous oxide, propylene, alcohol. 24. No dry sump motors. No external oil pumps. No vacuum pumps. No after market wet or dry sumps. OEM style oil pumps only. 25. Heads must remain in stock appearance on outside. Porting is allowed. No machining off the outside of head to install exhaust plates to raise ports. |
Guest
Posts: n/a
Chris,
Are you going to Indy with momand dad this year? |
Liked 7,754 Times in 1,741 Posts
First thing that came to my mind was 429/460 Ford.
Liked 880 Times in 311 Posts
429/460 = #25
I like the 70 mod LS-6 BB or even the '69 427 425 hp BB The conventional vortec BB might work, I have no experience with those BB heads, but if they are as good an upgrade as the SB Vortec it might work. The later Vortec 8100 has cast heads and could be the ticket, but it's 4.25 bore and 4.37 stroke makes it go about 10 over the cu in limit. Not sure if the induction would work, either. Destroke? If you like later mods then the LS truck engine w/ iron heads: Casting Number 373 Head: 1999-2000 LQ4 6.0 Litre Truck Material: Cast Iron Part Number: 12561873 Combustion Chamber Volume: 71.06cc Compression Ratio: 9.5:1 Intake Port Volume: 210cc Exhaust Port Volume: 75cc Intake Valve Diameter: 2.00 inches Exhaust Valve Diameter: 1.55 inches There is a thread on one of the LS forums that says the iron head can be made just as good as the LS-4 head can. There is a nice 4 BBl intake avaliable for them,too. Put those iron heads on a block with a larger bore and stroke it a little.. Let it fly!! What is the most common engine being used?
Adger Smith (Former SS) |
Liked 66 Times in 37 Posts
429 was my first thought, scary! If you are limited to production cyl. heads find the Biggest made!
72 cutlass |
Liked 100 Times in 45 Posts
Cummins in a Ram p/u.You did say pulling didn't you?:>):>):>)
Former NHRA #1945 Former IHRA #1945 T/SA |
Liked 1,831 Times in 415 Posts
Provided you can run an OEM replacement block, such as a BowTie, and you're willing to spin the thing up, a 4.5 bore 9.8" deck BowTie block with a 3.76" stroke crank (396/427) gives you 478 cubic inches. You can get real close to a 6.7" rod in that, allowing you to run a really light piston with a good ring package.
A set of 990 castings for the heads, since it says OEM castings and no aluminum (you'd need a cylinder head guy capable of Super Stock national record holder quality work). Probably a Super Victor Dominator pattern intake, and since they allow any single four barrel carburetor, you could talk to the guys at Quick Fuel about a really big Dominator pattern carburetor. I see no valve train rules, so I'd be looking at a big core (54MM) roller cam, 0.904" roller lifters, Jesel belt drive and shaft mount rockers. You have a really good choice of parts when you run a combination like that. Of course, with that big bore, short stroke, and long rod, that's a high RPM (8500 or higher) and wheel speed combination, not a "dead hook" combination.
Alan Roehrich 212A G/S |
For truck pulling all these engine options are no good. 12 valve ISB Cummins only way to go!
How about an iron headed 426 style Hemi?
Mark Walton 5789 SS, STK |
