#101 |
Liked 17 Times in 7 Posts
The "silver cooling machine" used by Gary Richard is this very unit and it's called "cold shot"
![]() Wade Mahaffey |
#102 |
Liked 174 Times in 39 Posts
Any idea how much it costs?
3207 D/SA, C/ED |
#103 |
Liked 100 Times in 45 Posts
If you have to ask............................................... .................:>):>):>)
Former NHRA #1945 Former IHRA #1945 T/SA |
#104 |
Liked 333 Times in 180 Posts
those units pictured probably "list" for at least $2500 to maybe as much as $4000 maybe even more depending on who ya got it from as well as the extras---the generators pictured add in another $800 to $1900-----close enuf for ya ???
#105 |
Liked 64 Times in 23 Posts
They are easy to make with a cooler and a submergible (sp?) pump. They've been used in other "heads up" drag racing for years.
Jody Aberts Troublemaker2 1966 Fairlane 427 |
#106 |
Liked 1,829 Times in 427 Posts
You can build one for less than $150.00.
Just Think!
james perrone 1290 STK |
#107 |
Liked 544 Times in 213 Posts
Don't forget to add the price of the golf cart and the extra crew necessary to get this stuff to the lanes when you need it........Pretty hard carrying a chiller machine full of ice and water and a generator from the lower forty.....
![]() Do they at least still give out a trophy for an Indy class win? Cause than it's definately worth it ![]() ![]()
#108 |
The silver unit "Cold Shot" is somewhere around $11-1200 and comes with the one way valve for the upper radiator hose. The one way valve has "Jiffy-Tite" quick disconnect fittings for easy operation. The units hold twenty-two gallons of water, however most folks are only using about half of that. The units are made one at a time and can be custom tailor made to fit your storage or operational needs. The inner vessel and outer cabinet are separated by insulation to keep the water as cold as possible.
Wade Mahaffey |
#109 |
Can be done much easier, cheaper, and smaller. Use a NOS size bottle full of liquid CO2 (liquid dry ice). Just make a heat exchanger type of manifold for the fuel to run through with the liquid CO2. You "ice down" the fuel in a matter of seconds in the staging lanes.
#110 | |
3207 D/SA, C/ED Last edited by Andrew Hill; 09-05-2011 at 10:38 AM. |
