Old 09-07-2011, 10:41 PM   #1
461stocker
Default rec port intake on oval head
Im thinking about trying a brodix dual plane rec port intake,in place of oval port rpm air gap, anybody been down this road before? The combo is a 460 hyd cam,closed chamber oval heads,no port work ,flat top.
461stocker is offline   Reply With Quote
Old 09-07-2011, 11:49 PM   #2
Liked 1,887 Times in 423 Posts
Default Re: rec port intake on oval head
Why?
Old 09-08-2011, 12:10 AM   #3
461stocker
Less low to mid range and more higher rpm power...Lookin for ways to go faster ...also we got a no port rule in the class ...thought the rec port might be better as cast...
Old 09-08-2011, 12:42 AM   #4
Then why not a single plane oval port?
Old 09-08-2011, 01:13 AM   #5
Mr.L-88
I have heard of people doing this and they claim to make power beyond that of the oval/oval combo. I have yet to see any back to back results; but Speedtalk has several threads on the subject. If your combo is as mild as it sounds I don't know how much you would gain.
Mr.L-88 is offline   Reply With Quote
Old 09-08-2011, 07:46 AM   #6
461stocker
the class has a dual plane only rule...
Old 09-08-2011, 08:50 AM   #7
You'll find that most modern dual planes of the same pattern are relatively equal. I'd say there's considerably more power to be found elsewhere.
