Old 10-25-2011, 09:22 AM   #1
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Front bushing kit A-body dodge
I'm going to put in new front end part's in my demon.What are guy's using for bushing? any info would be good.I would like to do it right the first time?
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 10-25-2011, 11:50 AM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Front bushing kit A-body dodge
When I had mine done, I used the polyurathane (spelling?) material from Energy Suspension for the strut rods and Moog rubber in the control arms. I was told that the poly control arm bushing tend to bind/be tighter than regular rubber. Can't afford the needle bearing stuff.
Old 10-25-2011, 10:37 PM   #3
340Cuda
Liked 805 Times in 341 Posts
Default Re: Front bushing kit A-body dodge
Just replaced the upper control arm bushings in our 69 Cuda. We used the Moog offset bushings to we could finally get a little caster.
Bill
Old 10-26-2011, 08:09 PM   #4
George Mirza
Kelly check these out, pretty trick and expensive I would guess. But if you want to do it right this is the way to go. Maybe someday I'll do it right!
http://www.garysautomotive.net/
George
George Mirza is offline   Reply With Quote
Old 10-26-2011, 11:28 PM   #5
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Prothane makes some great bushings. Used them on my SS/AH Barracuda. Check their website. Dyno
