#21 |
Liked 974 Times in 310 Posts
Why is everybody trying to reinvent the wheel? Do the Smith lifters work? Yes they do and for the price of a new engine it's cheap insurance.
#22 |
Liked 68 Times in 31 Posts
Do Smith lifters work? yes they do, and they also fail occasionally and when they do
it costs you a new engine. The ceramic puck is like grinding compound when they fail and break apart. It may not even be the lifters fault, you could break a rocker and start the process, all i know is it costs a lot when it happens.
Ron Mattson 5015 STK |
#23 |
Liked 320 Times in 102 Posts
This is just an exercise in futility............
I see on another post from Greg Hill that he has the inside scoop from Comp Cams that roller rockers will be legal next year........... If that happens how far behind are roller lifters????????????? The next step will be to remove the Stock Eliminator section from the NHRA Rule Book Let me recap the events that killed Stock Eliminator..... Removal of the OEM spring pressure & size rule Removal of the cam duration rule & cams designed with lift rates to take advantage of the above change Lifters designed to take advantage of the above Roller rockers to take advantage of the above rule How can roller lifters not be the next rule to take advantage of the above rule changes??? The last Stock rule change will be an additional S to make it SS
#24 |
Boy !
I must have the stockest stocker out there cause i ain't got none of all these goodies. Just plain ole ..Old school....No wonder my s@#t don't run... ![]()
Danny Waters, Sr / 73 Duster "340" |
#25 |
Liked 49 Times in 15 Posts
Ron, I guess broken rockers will be a thing of the past.........
Dean Feiock -- Stock 5002 |
#26 |
Liked 1,892 Times in 423 Posts
Yeah, next up, broken rocker studs .................................
Alan Roehrich 212A G/S |
#27 |
xx
#28 |
xx
