Liked 68 Times in 41 Posts
I'm going to put in new front end part's in my demon.What are guy's using for bushing? any info would be good.I would like to do it right the first time?
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 138 Times in 51 Posts
When I had mine done, I used the polyurathane (spelling?) material from Energy Suspension for the strut rods and Moog rubber in the control arms. I was told that the poly control arm bushing tend to bind/be tighter than regular rubber. Can't afford the needle bearing stuff.
Liked 805 Times in 341 Posts
Just replaced the upper control arm bushings in our 69 Cuda. We used the Moog offset bushings to we could finally get a little caster.
Bill |
Kelly check these out, pretty trick and expensive I would guess. But if you want to do it right this is the way to go. Maybe someday I'll do it right!
http://www.garysautomotive.net/ George |
Liked 693 Times in 205 Posts
Prothane makes some great bushings. Used them on my SS/AH Barracuda. Check their website. Dyno
