Old 11-22-2011, 06:57 PM   #51
Liked 1,892 Times in 423 Posts
Default Re: 2012 Rules Are Posted
There are stud conversions that do not require machining.
You are allowed to drill and tap for screw in studs anyway.
The question would be, if NHRA requires the OEM configuration, what does NHRA consider the configuration of the Olds and Ford 5.0 to be? It's not a shaft mount, by any stretch. But neither is it a stud mount.
I'd suggest anyone considering making changes wait until at least after the PRI Show next week in Orlando, and what ever you decide, get approval from Glendora in writing, and keep it with the car at all times.
Old 11-22-2011, 09:40 PM   #52
SS Engine Guy
Aftermarket rockers. And more spring pressure. And nothing about ratios which will work much better with different ramp angles on cams which will require more spring pressure. Speeding up opening and closing intervals. And you can only get so much spring without bigger diameter valve pockets. (next change) Sounds reasonable to me------------In SUPERSTOCK. If you can't make a stock rocker live with the mods allowed you probably should be running in a class that already allows aftermarket rockers. Not screwing up a class that is screwed up enough by all the whining, and aftermarket BS that has already been allowed. As many have stated deregulating spring pressures caused this.
Just what we need, or so I'm told, more classes. I thought the manufacturers wanted less classes? Which is it?
SS Engine Guy is offline   Reply With Quote
Old 11-22-2011, 10:52 PM   #53
buzzinhalfdozen
Liked 11 Times in 8 Posts
You know I wondered how long it would take for these folks to find 1 more thing for us to spend our money on. Guess buying a new window net every 2 years won't break the bank but where does it end? Heck we've got the local circle track racers buying our outdated belts to run....they have no time limit rules, guess they're alot less likely to crash.
Joe Buchanan SS/BX 3117
Old 11-23-2011, 01:26 AM   #54
Bernie Cunningham
Liked 52 Times in 17 Posts
X2 , where the heck did this come from ????!!!!!!!!!!!!!!!!!!!!
just go ahead and dilute us again cause of a few whinny people (or rich) get there way!!!! sounds like US politics, buggar !!!!!!!!!!!!!!!
Bernie Cunningham 7053 STK
Bernie Cunningham is offline   Reply With Quote
Old 11-23-2011, 02:21 AM   #55
Dan Lattimore
Liked 154 Times in 37 Posts
Originally Posted by Jim Kaekel View Post
I wonder what will be acceptable for pedestal mount rocker arms like Olds or some Fords?
Jim, You have a pm.
66W30POST
Dan Lattimore is offline   Reply With Quote
Old 11-23-2011, 10:11 AM   #56
keith ohanesian
I just want to change my seat so when some dude having a mid-life crisis crosses the centerline behind me in his 8.50 9 inch tire car and punts me like a feild goal kicker, my seat doesn't fall apart.. Oh! Or me... But hell everyone else wants roller rockers and pro stock spring pressures.
No prep is king
keith ohanesian is offline   Reply With Quote
Old 11-23-2011, 11:01 AM   #57
Mickey Whaley
The seat must not be important keith just get a nice window net instead
Mickey Whaley is offline   Reply With Quote
Old 11-23-2011, 11:32 AM   #58
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
X3 Bernie!!
I hope all the whiners and cry babies are happy!
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
Old 11-23-2011, 11:39 AM   #59
jmcarter
jmcarter's Avatar
Liked 3,226 Times in 981 Posts
Agree 1000%; like Alan and others have said, the new rockers will just move the weak link to another component (my spare $1200 "OEM" rockers now being virtually worthless), meanwhile they want us to spend $ on 'safety changes' that make the SCCA crowd laugh. Guys wearing their pajamas brought about the pant rule (which I agree with because it truly advances safety) and now others whine because they can't fix their rocker arm issues and cause everyone to spend a bunch of money to update their stuff which they worked to figure out and make work. Chances are the net thing is just because some racers use raggedy old nets so NHRA wants to uphold the "appearances". I guess well anchored true racing seats just makes too much sense, besides wouldn't want to violate the spirit of "stock". Take a good look at some of the 'stockers' that some master craftsmen have built and tell me how a good seat would in any way take the car away from 'stock'. Give me a break..
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-23-2011, 12:33 PM   #60
Stocker 2
Originally Posted by Sam Murray View Post
X3 Bernie!!
They are! Once again they got their way. To He// with everyone else.
Stocker 2 is offline   Reply With Quote
