I was told I could use an anti-rollbar on the rearend in stock but it had to be a bolt-in unit.
Is it legal to weld in box tubing for mounting the anti-rollbar? Check out this installation: http://www.competitionplus.com/drag-...via-suspension |
Liked 55 Times in 14 Posts
looks bogus to me. If I was from that area I would protest.
And the "rule book" says what about anit roll bars???
Shawn Allsup K/S 718 |
Liked 370 Times in 101 Posts
ahhh...I think it says nothing....traction devices are "supposed " to be bolt on, anti-roll bar is not a traction bar, I've looked under many stockers,lots have them and all were welded in.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
^^^ Yep! Mine is welded in.
Liked 57 Times in 33 Posts
You can tack weld the anti roll bar in place and bolt it, but i was told you could not completely weld the unit in. Thats the way mine is put it, works great and never had a issue.
Duane Eiskant 1354 Stock/Super Stock |
#7 | |
Liked 7,862 Times in 1,750 Posts
To answer the question, no it's not legal but all of the late model F bodies that I've looked at have them welded in and the particular kit in that article is meant to be welded in. NHRA should spend some time looking under cars instead of just looking under hoods.
#8 | |
Chad Rhodes 2113 I/SA |
I can't find that one. Could you please point out where that is in the book?
#10 | |
I looked for that in the rulebook before I asked the question. I did not see any such statement in the stock section. The only allowable addition I can find is the connectors between front and rear subframes. |
