#21 |
Liked 8 Times in 4 Posts
Just ask Robert Pond if an anti-roll bar is considered a traction device. From what I have been told he had to move his from inside the trunk to under the car. At that time NHRA ruled it as a traction device and said he could continue using it as long as it was bolted in. I do believe the brackets can be welded to the rearend housing but thats all.
#22 |
Liked 62 Times in 21 Posts
I went to a lot of trouble back in the day to put an anti-roll bar in my car and make it 100% bolt in. Worked like a champ but definitely would have been easier to weld it in.
#23 |
Liked 3 Times in 1 Post
If the "weld on" style are legal, I'll be changing mine over. I have some issues with my bolt on system, some welding would correct these problems.
Wade |
#24 |
Here's one that is 100% bolt on and used by several Stockers and even some 9"tire SS. It works!
http://www.hrpartsandstuff.com/produ...nd/swaybar.htm Tom |
#25 | |
Liked 203 Times in 52 Posts
Kevin |
#26 |
Liked 9 Times in 3 Posts
Mark Markow 171 ss/tb |
#27 |
Sway bar = panhard bar. Locates the rear end side-to-side. Anti-roll bars control body roll. Two separate components. Body roll & side-to-side sway are two different things.
At least that's according to GM shop manuals.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 12-02-2011 at 10:41 PM. |
#28 |
And still... no one can post where the rule book states that you CAN'T weld in an anti-roll bar......
Shawn Allsup K/S 718 |
#29 |
i'm not looking for an argument but, i guess i'll have to disagree with gm on that one . how in the world a (sway bar = a panhard rod) is beyond me. i guess a camaro with a front sway locates the front end? LOL. in my opinion a sway bar and a anti roll bar are the exact same thing. they both control body roll. i guess technically it should be called an anti-swaybar
Mark Markow 171 ss/tb Last edited by Mark Markow; 12-02-2011 at 10:58 PM. |
#30 |
Mark, sway is side-to-side. A panhard bar locates/centers the rear end under the car side-to-side, but will not control body roll.
That front bar is anti-roll also.
Ed Wright 4156 SS/JA |
