Old 12-02-2011, 11:17 PM   #31
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Is this legal?
i have built a couple of sway bars for customers and made sure they where bolt in,,it should be good but if your welding in supports on the frame like in the "chevy artical" i wouldn't think it would fly gmonde
Old 12-03-2011, 01:13 AM   #32
hookdaddy
Liked 8 Times in 3 Posts
You need to go back and look at the pictures again - the part that welds in under the floor is designed the reinforce the frame under the rear roll bar braces. The anti-roll bar bolts to those braces. A technicallty? Maybe but acceptable yep. The part has been around for years and is under several national & division winning Camaros & Firebirds including a recent world champs car. It's been looked at by tech guys in several of the divisions - never a problem.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
Old 12-03-2011, 08:38 AM   #33
Billy Nees
Originally Posted by hookdaddy View Post
You need to go back and look at the pictures again - the part that welds in under the floor is designed the reinforce the frame under the rear roll bar braces. The anti-roll bar bolts to those braces. A technicallty? Maybe but acceptable yep. The part has been around for years and is under several national & division winning Camaros & Firebirds including a recent world champs car. It's been looked at by tech guys in most of the divisions - never a problem.
Well, there you have it boys! A technicality! Thanks Don.
Billy Nees 1188 STK, SS
Old 12-03-2011, 07:27 PM   #34
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Originally Posted by Pete Muenzer View Post
Has anyone used this type? I would think this one would have no issues since it is all bolt in.
http://www.spohn.net/shop/1982-1992-...-Sway-Bar.html
That's a "solid" bar..... Much more weight than the http://www.hrpartsandstuff.com/produ...nd/swaybar.htm bar.... Just a FYI post...
Old 12-03-2011, 10:19 PM   #35
nolongerracing
Liked 72 Times in 27 Posts
Mark, sway is side-to-side. A panhard bar locates/centers the rear end under the car side-to-side, but will not control body roll.
That front bar is anti-roll also.
Why do my 2 stock street Camaros have both a panhard bar and a sway bar on the rear if both do the same thing?
nolongerracing is offline   Reply With Quote
Old 12-03-2011, 10:31 PM   #36
Ed Wright
Ed Wright's Avatar
It doesn't. It has a Panhard or sway bar and that bar connecting the two lower control arms is an anti-roll bar.
Ed Wright 4156 SS/JA
Old 12-03-2011, 10:50 PM   #37
nolongerracing
Sway bar = panhard bar. Locates the rear end side-to-side. Anti-roll bars control body roll. Two separate components. Body roll & side-to-side sway are two different things.
At least that's according to GM shop manuals.
I'm confused with your answers....if sway bar = panhard bar, why does my cars have both? These are mid 80's Camaros. They have a bar that connects the body to the rearend housing...panhard. They do not have a bar that connects the lower contol arms. They have a bar that connects to the body and the rear end. Is that an anti-roll bar? If so, why is it not legal to replace it with the aftermarket anti-roll bar?
Old 12-03-2011, 11:08 PM   #38
Ed Wright
Ed Wright's Avatar
As I said, the bar that bolts between the F body lower control arms is an anti roll bar. The bar running from the driver's side end of the rear end housing to the bracket on the frame, passenger side, prevents side-to-side sway. Some people tend to cal the anti roll bar a sway bar also. That is not accurate, but you go ahead and call it what you want.
Old 12-03-2011, 11:15 PM   #39
hookdaddy
Maybe, Billy , Maybe
Don Scholl
Old 12-03-2011, 11:47 PM   #40
nolongerracing
Anti-roll, anti-sway or stabilizer (according to GM parts) are all the same. The purpose of the panhard bar (axel tie rod according to GM parts) is to only keep the housing centered in the car. It is not a side to side "sway bar". So if it came with an anti-roll, why can't it be replaced with an aftermarket unit?
