#51 |
Todd, you don't mind the Powerglide Mustangs? LOL
Ed Wright 4156 SS/JA |
#52 |
Liked 203 Times in 80 Posts
One Question ? What Teardown ?? How many times has HP been hit and someone gets a teardown because of it ?? lol
When the 5.7 Challenger went 1.24 under at the points meet in Joliet this year Keith and Dave took it apart and Travis Miller conducted the inspection. http://www.dragracecentral.com/DRCSt...r2011#indextop
Mike Fuller 396 STK 3961 SS |
#53 |
Run that far under in Div 4 your likely to get looked at also.
#54 |
I was at the test and tune session in Bradenton FL this week and seen the new camaro run . Car look very stiff , from what I saw the best run was tue morning with the 427 motor .
The supercharger motor did not seem to run the first 1/8 mile at all . The guys from GM took every time slip and showed them to no one . I think the car weight was around 3200 lbs with the driver in it . The car is reported to weight 3000 lbs and had no weight in it anywhere except the driver With the reported times the car looks good on the surface , but if you compare my stock 2008 CJ at NHRA legal weight of 3665 lbs and I ran a 9.53 with 1.31 60ft right after what I thought was the camaro best run . If I took out 450lbs I would have ran 9.10 . My mph was a best of 137mph and most of the day was 135.75 mph which was off 3 - 4 mph The pro stock's mph seemed to be off a couple mph which I think was do to the track prep. If the 140 mph is true thats pretty good One thing that I was curious about was the supercharged motor . For stock the block is suposed to be aluminun but the block in the car was steel (LSX) also the blower looked like the 4L unit GM , show us the time slips , my times were posted on the board if your telling us what it ran show the slips ? Air at the track was very steady over the 2 days of testing Temp 75 - 80 RH 45 - 55 % BAR 30.05 - 30.10 DA 2400 - 2900 ft CF 102.8 - 1.037 Fastest pass for me Tue morning First run 2008 CJ stock motor F.A.S.T. system with MSD coils Santuff shock's fron & rear B&B spindles and rear end upgrade stock rear gears & C4
Bo Kenney |
#55 | ||
Liked 2,359 Times in 557 Posts
#56 |
Liked 7 Times in 4 Posts
Ya ,My point was that it should be a rule if you hit the AHFS with added HP it should be a automatic Looksee to see if everything is Cool First !! I dont see or hear that very much Should be cool to see these guys step down now in the new cars in there own classes,wonder if they will give us back the .30 on the index now lol ya rightttt.
Bob Aceves, 746 E/SA A&M motorsports Last edited by B Aceves; 12-07-2011 at 11:38 PM. |
#57 |
Here's the 427 n/a test run.
#58 |
Troy that was not the first test run , maybe second or 3rd . First run was very solid . Then they had issues the rest of the day and it left early
Bo Kenney |
#59 |
#60 |
Banned
Liked 5 Times in 3 Posts
Tear down with head studs is not much more difficult than with head bolts. All ARP head studs have an Allen hex made into the top of the stud so u break the nuts loose then just unscrew the stud out of the block using the Allen hex on the stud just like you were un screwing a head bolt...trust me I've pulled a iron hemi head off of a 68 cuda numerous times with heads studs and if it can be done on that thing it's gonna be SIMPLE to pull an aluminum small block head off that thing...lol
