#11 |
Liked 507 Times in 92 Posts
If I knew how to post a picture, I'd post a 1956 Merc with the 2 x 4 tea pot carb engine that was in my friends shop not too long ago.
Casey Miles 248H Stock? |
#12 |
1956 Ford and Merc 312 cu in, 2 x 4 were rated at 260 HP. 56 Ford/Merc 312 single quad was rated 225/230 HP. Also NASCAR Ford's ran "tea pot"carbs but Merc's had option of Carter WCFB's. Popular cheater trick was to use bigger Cadillac Eldorado carbs for 5 to10 HP advantage. 57 Ford had 2, 2 x 4 combinations 270 HP with small cam and 285 with big cam, both 312 Cu In. I've never seen factory assy. line built 2 x 4 292 cu in cars, but alot of wierd combo's could be built if you knew someone!
#13 | |
Banned
The dealer paper I have shows tea pot Holleys, Mercury did use the Carter Wcfb's on the 1957 M-335 which was the 368 Lincoln engine used in the Mercurys Bill Strope built the engines for them there is a article in Hot Rod 1957 on the M-335s
#14 |
I stand corrected as I found a picture of the 260 HP Merc engine in Hot Rod (May 1956) and they are definetly Holley's. Article was on Speedweeks at Daytona Beach. I guess my memory isn't what it used to be. Regards, Fred
#15 |
Liked 307 Times in 103 Posts
I can't speak for Travis,but I took his post as how much somethings are still the same now as they were in 1955.
I thought it was neat to read article. Mike Taylor 3601 |
#16 | |
Liked 1,434 Times in 299 Posts
James Schaechter 3163 STK |
#17 |
Whats STOCK about stock eliminator any more any way? with all the valve train rules, light weight parts. 2 steps, metric tranys in cars that they did not come with. The hundreds of pounds of weight shoved behind the rear tires. Some one please answer the question! this is not what the class was made for. you can tell me a 4000 lb car with a 283 that has a 1.70 60ft should pull the tires 2 foot in the air. Not that any one cares what i think, nor would i expect you to. no one cares about the little guy trying to get into stock, or the guys that have suported the sport for the last 40 years that dont have the health and or the money to throw at the cars like every one else. you just want the indexs lowered to run them out! great idea! I think every one needs to take a step back and remember what stock eliminator was supose to be, Now its just super stock on a 9 inch tire. Well i said what i had to.
Mike Dean 3870 |
#18 |
Liked 4 Times in 4 Posts
Mike,
You are right, back in the day a Stocker was stock. I remember a race at Atco where a Stock ' 50 Studebaker was disqualified because he had a non-stock muffler on his car. When I left the country for my Southeast Asian vacation in 1969 the class record for SS/CA was low 11's if memory serves. There will always be people that will push the rules, some that will cheat and others that will play within the rules and the HRA's will continue to amend rules to help Speed Equipment manufactor's make more money and appease some racer's need for more speed. JimR
Jim Rountree |
