Old 03-06-2012, 12:32 PM   #11
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: Front springs
Tony Monico......
He has a very nice 72 Nova.....ran a little S/ST and some bracket racing in the past. Used to run Mid 10's with a 350.
He built a 502 himself......He's trying to get out and make license runs soon.
Glad to hear Ricky is up and running fine and hopefully it stays that way for a season.....
Rich Biebel
S/C 1479
Stock 147R
Old 03-06-2012, 01:48 PM   #12
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Santhuff springs are machined flat on both ends of their springs and you have to remove 1 coil on 1 end so the fit in spring pocket in lower control arm of Camaros, chevelles, novas etc. You can fit the flat end in it if you like, I would not as it does not fit into the pocket in the lower arm then.
I cut mine. fit fine. Santhuff says no problem cutting them as first coil is a dead coil as they put it.
chris ok is offline   Reply With Quote
Old 03-06-2012, 01:54 PM   #13
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Originally Posted by Rich Biebel View Post
Tony Monico......
Rich, I remember his car, yes it was very nice.
Old 03-06-2012, 04:23 PM   #14
1320racer
1320racer's Avatar
I asked bob gonier, a member here what coil spring is he running on his small tire, super street Nova who's build was featured by Evan Smith in National Dragster last year and he told me told me he runs Santhuff's 180 lb. spring. He did say however that the springs are at coil bind and the lower control arms on the bump stops.
Old 03-06-2012, 06:53 PM   #15
Greg Barsamian
Liked 427 Times in 97 Posts
QUOTE=1320racer
On the Moroso Trick springs, the complaint I heard from many going back over 20 years is the quality of the spring is no longer what it was and depending on who you talk to, there are some that have stated the springs were dead in less than a full season of racing.
X2 on the "Trick Springs"
(hint) go back and read post #5 and "use what's suggested"
some of the "best kept secrets" are right in front of you!
Old 03-06-2012, 07:05 PM   #16
40Coupe
Santhuff 180's here with 1900 lbs of nose weight.
I think the 200's would be ideal for the combo.
'67 Camaro
1.25
5.77 @ 118
40Coupe is offline   Reply With Quote
Old 03-06-2012, 10:22 PM   #17
HP HUNTER
Liked 372 Times in 129 Posts
Originally Posted by 1320racer View Post
Mark, your latest reply in yet another thread I have offered advice to the op's specific question, further demonstrates that you're clueless and your sole objective here is to attempt to discredit any advice I offer, while you ignore the op's question.
Ive got nothing to add to your good advice, that car is just too much, wild and woolley
Old 03-06-2012, 10:31 PM   #18
40Coupe
Santhuff's certainly make for a "wild and wooly" ride. LOL
'67 Camaro
1.25
5.77 @ 118
Old 03-07-2012, 08:19 AM   #19
Rich Biebel
Nice.....but tettering on the edge of disaster......one little move left or right and your toast.....
Calm that thing down ......and put a wheelie bar on it.......guardwalls and sheet metal don't mix well........and oil pans don't usually look good if you bail out of one of those big wheelies.....
Rich Biebel
S/C 1479
Stock 147R
Old 03-07-2012, 08:48 AM   #20
40Coupe
No kidding!
'67 Camaro
1.25
5.77 @ 118
