Old 04-09-2012, 08:59 AM   #1
tgriffith
Default rear shock location?
are the rear shocks allowed to be moved at all??
76/77 nova
tgriffith is offline   Reply With Quote
Old 04-10-2012, 07:04 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
Default Re: rear shock location?
In stock, no you can not move the rear shocks.
In superstock yes you can move stuff.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 04-10-2012, 08:26 PM   #3
Tom Turner
Apparently; The upper shock mount is no longer an issue with tech. That being said; I would remain on the side of caution. (Dont move too far). If you look carefully, you will find that many of the purpose built cars in Stock are not EXACTLY as per O.E.M.
If you remain conservative; the other racers with similar cars will be the only people looking.
Tom Turner is offline   Reply With Quote
Old 04-11-2012, 11:39 AM   #4
tgriffith
77 nova-- the stock location appears to have been on the outside of the frame, which is really close to the rear wheel. The upper location has been moved inches just inside the frame.....wonder if thats legal??
thanks
