Old 04-10-2012, 08:56 PM   #1
79transam
Default how do i know what to pick with a converter
im going to buy a new bte converter. everyone i talked to says i need a 5500 stall. my trans guy is wanting me to get a 5000 stall. i run a 434 sbc in a 79 transam, i run a glide with a brake, shift at 6500 launch at 3500 i have a lunati solid roller cam the duration at 50 is 276/284 gross lift is 640/645 rpm range 4400-7800. ive never weighed the car but would guess around 3k. im lost with this. ive tried finding stuff on the net to read but its like a soup recipe everyone has a different opinion, if i go with the 5k what is the adverse affect of this? same with the larger stall. thanks for all your guys help i needed some expert advise so i came to the experts.
79transam is offline   Reply With Quote
Old 04-10-2012, 11:19 PM   #2
Phillip marvetz
Phillip marvetz's Avatar
Default Re: how do i know what to pick with a converter
I would ask the people at BTE.
2009 V/SA Record Holder
Old 04-10-2012, 11:29 PM   #3
rustbucket79
I presume the 4400 to 7800 RPM range is in reference to the cam manufacturer's suggestion rather than your engine's actual powerband.
I've always had good results choosing a stall somewhere between 1500 and 2000 lower than peak engine RPM. Also, better to stay with a more efficient (tight) 8" converter that can be restalled higher if required rather than a loose 10" converter that's maxed out and has horrible slippage numbers down track.
Do you have a dyno sheet?
rustbucket79 is offline   Reply With Quote
Old 04-11-2012, 05:05 AM   #4
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Shift at 6500, in a sbc?
Old 04-11-2012, 06:52 AM   #5
Greg Hill
Liked 279 Times in 68 Posts
Call Charlie Plott at ATI. Your stall speed will depend on if you're going for maximum performance or something else.
Greg Hill 4171 STK
Old 04-11-2012, 09:18 AM   #6
Ed Wright
Ed Wright's Avatar
Originally Posted by greg hill View Post
call charlie plott at ati. Your stall speed will depend on if you're going for maximum performance or something else.
x200!!
Ed Wright 4156 SS/JA
Old 04-11-2012, 10:42 AM   #7
Ron Middleton
Liked 12 Times in 4 Posts
Talk to Bubba Stanton at BTE and follow his recommendation. They've built many convertors for your type application and they do a real good job of it. I've sold quite a few of their converters and never a problem. JMT.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 04-11-2012, 11:30 AM   #8
mannymen
Liked 13 Times in 7 Posts
You are best spending $400 for a half day on the dyno to determine the right converter for you engine. You will get it right the first time and it will save you a TON of money in the long run. Nothing like spending $900-$1200 on a converter and not having the right one, then having to spend another $1000 trying to figure it out.
N/A
mannymen is offline   Reply With Quote
Old 04-11-2012, 11:48 AM   #9
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
While I agree with those that advised speaking to Charlie Plott/ATI, the bottomline is without actual dyno info or at the very least good dyno simulation info, your sucess at getting the right converter is a matter of who guesses the best.
Old 04-14-2012, 07:23 PM   #10
philbilly
philbilly's Avatar
I just got home from a couple days of Scottys school. It was free testing of converters, carbs, fuels, trannys,etc. Alot of good products I tested 5 different converters in the last 2 days. I was able to pick up my stocker 5 tenths in the quarter mile over the converter I started with. Money well spent. Alot of work but I didnt waste any money trying to find some e.t. Its not everyday I get to test products for free. You can also learn a bit why your there.
philbilly is offline   Reply With Quote
