#21 |
Liked 699 Times in 202 Posts
I have no issue with the weight of any of the new cars. I'm just amazed at the weight difference between the street version and the class guide.
I started construction on a '67 shelby stocker (untill the economy put it on hold) and the class guide shows a weight of 3187lb. only 70lbs lighter than the camaro. I didn't know all of that street legal technology was that heavy. The camaro sure looks a lot larger and heavier than my '67 mustang. If I could take out the same percentage of weight my car would weigh about 2700lbs. The problem is it still wouldn't be competitive with the new cars. |
#22 |
Liked 2,355 Times in 554 Posts
You would be really surprised at the weights of everything in a new car. The stock harness on my 1995 Formula was about 40 lbs! The same goes for the carpet. I scraped over 30 lbs of deadener and sealer out of my body-in-white 2010 Camaro. That is before you look at the stuff the government now mandates. Ever pick up the rims on a new Camaro?
#23 |
Just to give some insight on the real numbers of this 427 NA engine, I have been running close to the same combination in my 68 camaro in bracket mode for the past year. 427 LS7 NA, originally Z06 motor, replaced pistons with 12:5 compression Ross, have close to the same cam as the COPO, powerglide, but with a 950 carb setup, stock GM 4-barrel intake. Car runs 6.0's in the 1/8 shifting at 6800. Dynoed with a fresh motor this year at over 700 hp @6800. Figure how much more the COPO would be capable of from reported rumored 9.69 after the engine/chassis experts get more run time, go to full race tune, running it up to 7500 rpm.
#24 |
Liked 70 Times in 22 Posts
Byron
Not sure the 275 vs 425 is that far off. Adjust for cid and the 275 goes to 325. WJ says a point of CR is 4% so thats another 12 % or 365 HP. Then the light valves, the 33% larger throttle body opening and the .640 vs .490 cam and its pretty close. What is .150 lift worth? Maybe its even in favor of the 427. Not sure the TB difference gets much since I doubt its the choke point on either engine, but it sure doesn't hurt. Either way it will make a slick stocker.
Stewart Way 2424 SS |
#25 |
Liked 325 Times in 50 Posts
Byron knows the old 360 is a truck motor, and of course the Chev is a race motor. Thats about the same. i can tell the chevy guys are happier already. Don't you think so Stewart? I'm glad they are feeling better.
Jeff Teuton 4022 STK |
#26 |
Liked 175 Times in 78 Posts
Ya think
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
#27 | |
69 Pure/Stock Yenko Camaro 11.73 @ 118 |
#28 |
Your right Jeff. But compare the (race) 427 to the 6.1 hemi. The hemi has the smaller TB, around 2 pts less compression, less cam and the 427 is rated less than 1 hp/ci and the hemi started at more than 1 hp/ci. If you correct the 6.1 370/385hp to 427 inches and for the additional compression the 6.1 would be over 470hp.
The 5.7 hemi at 305 hp is likely closer to the 427 and everyone complained about the 5.7. If you correct the 5.7/305hp for compression and inches its about 400hp. The TB, valves and additional cam may be worth the other 25hp. Why isn't everyone complaining about the 427/425 rating? I can remember threads where Mopar (and Ford) folks were called immoral and unethical but I doubt we will hear that about the Chevy guys. And we shouldn't.
#29 |
Liked 58 Times in 18 Posts
If you want to compare OLD vers NEW look at the 427/ 425hp L72 1969 and then check the spec's on the new copo 427/ 425hp. All these new cars are NOT STOCK ELIMINATOR CARS PLAIN AND SIMPLE!!!!
#30 |
Liked 120 Times in 42 Posts
I am sure you do not like the new COPO ,but NHRA has put them in the classguide and they are hear to stay whether you like it are not.I think the new cars will put a few more young fans in the stands and that will be good for NHRA Drag Racing.
