Old 05-01-2012, 10:20 AM   #11
Ed Wright
Ed Wright's Avatar
Default Re: wrong spec submitted by MOPAR
Originally Posted by Greg Hill View Post
A professional stock eliminator engine builder would have measured the valve the right way and in Irvin's case with no number on top of the piston would have called California for clarification. You can't assume these motors are going to be right when you get them.
And Salty Dog said: Who are their engine builders?
That is who I would be blaming, not MOPAR. Who takes an OEM engine and just runs it? Do that and you deserve what you get. Ever hear of production tolerances? The "engine builder" had to have access to NHRA's specs. Why was everything not measured?
Ed Wright 4156 SS/JA
Old 05-01-2012, 11:34 AM   #12
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
Now that was an unexpected response ED
You could hardly call these OEM motors - they are complete "race ready" spec motors from Arrow Racing and two of them had been through NHRA tear down before and passed
I know Arrow built these as good as any engine builder out there - they just did not know MOPAR made a mistake - they used the valve which was identifed to go in the heads - stock size for a Gen IV viper engine - The TI sheet was submitted to NHRA after the engine building started - the valves used were appearently incorrectly measured by MOPAR engineering - used a blue print to figure out how to do it - LMFAO
"this is not your father's Oldsmobile"
Ron
Old 05-01-2012, 01:02 PM   #13
Ed Wright
Ed Wright's Avatar
What you do is measure everything against NHRA specs. That's what you go by.
If that is who built it, they should not have assumed. I would be concerned if I owned one.
I hope they don't charge much. LOL
Old 05-01-2012, 02:52 PM   #14
Andys dad
Andys dad's Avatar
Thanks for the instruction
No Problem - all MOPAR had to do was submit the corrected TI sheet
Its a beautiful thing
Ron
Old 05-01-2012, 03:02 PM   #15
Ed Wright
Ed Wright's Avatar
Comes down to one thing: all the engine builder had to do was measure everything. That simple. That is who is at fault. If I couldn't do my own I would use a known builder of NHRA legal engines. Not some road racers.
Old 05-01-2012, 03:38 PM   #16
ALMACK
ALMACK's Avatar
Liked 369 Times in 127 Posts
oh well ***** happens...still a damn fine looking Drag Pak Challenger though.
Cool looking car !
20-30 years from now, it will still look cool.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 05-01-2012, 05:13 PM   #17
Greg Hill
Liked 279 Times in 68 Posts
Ron
You can't assume anything is right. You have to measure. Do you think that Arrow rolled the cam and checked every lobe to make sure the lift is right? I bet Don Little or Bruce Parsons or Bub Whitaker would have. Do you think they poured all the runners or every combustion chamber? Did they weigh a piston and rod assembly? All of us have to play by these rules. So Chrysler gets to change the spec after the fact. Why doesn't that surprise me.
Greg Hill 4171 STK
Old 05-01-2012, 05:23 PM   #18
Ed Wright
Ed Wright's Avatar
Could be the vendor (chances are MOPAR didn't actually make the valves.) missed the spec. Can't blame MOPAR. It's the builder.
Old 05-01-2012, 05:27 PM   #19
Andys dad
Andys dad's Avatar
I am glad MOPAR was willing to help all of the people out who really made the mistake and changed the TI sheet with NHRA
Old 05-01-2012, 05:53 PM   #20
Liked 1,788 Times in 408 Posts
It's too bad a "clerical error" got someone DQ'd.
The flip side is that I check all my parts against the blueprint guide from NHRA. Jimmy Bridges does my heads, and he checks everything he does, every chamber and every port, my heads have Jimmy's cc numbers all over them when I get them. I check the valves before I ever give them to Jimmy, and then he and Chris check them again. That's the great thing about having a guy like Jimmy do your stuff. Jimmy will tell you that "if you get torn down, I'll be there like Johnny on the Spot".
