Liked 152 Times in 26 Posts
years ago moroso listed a part no. for there trick front springs for a mid year vette and of course now they dont, does anybody know if a nova or camaro of that era is the same? car has a big block. thanks for any help. lynn engels
Santhuff is the way to go. They will want some accurate info (scale weights and desired ride height, etc) but their stuff is pretty much right on.
Liked 231 Times in 107 Posts
The Moroso Camaro's fit but, your might have to trim length a hair.
Lynn,
I use Moroso trick front springs, p/n 47230 on my '71 Big Block Corvette. They are 5.00" OD, 16.1" tall, with a rating of 217 lb/in. I installed them as-is, and I'm very happy with how the car sits. Hope this helps. Good luck -Ben B/S 3869 |
Liked 83 Times in 24 Posts
Old post i know...
any idea what Moroso's for a tunnel ram -iron head small block? Thanks Dom |
Liked 482 Times in 159 Posts
get back to you shortly ...
Old Moroso (approx 1979) listing # 4714 1967-69 Camaro,small block- Modified,1968-77 Nova,small block- Modified.
* Modified - Battery in trunk and / or fiberglass hood. #4715 1967-69 Camaro, small block -Super Stock, 1968-77 Nova,small block -Super Stock. *Super Stock - front end is same as factory weight, minimum of lightweight substitutions. Current part #'s are 47140 and 47150. |
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Lynn
I can get you what you need Give me a call 717-793-6819
Marty Rinehart Jr 1125 SS STK SG SC SST |
Thanks guys
So,the camaro springs are the same dia. as the vette? |
yes
