Liked 165 Times in 59 Posts
has anyone had any problem breaking the jerico shift arm ecentric that actuates the 3-4 shift fork ,, we have the shifter stops inplace ,, we are on the second one ecentric ,,,the bore in the trans case for the ecentric is not oblonged or enlarged ,,,the shift fork checks out good(not bent or distorted) this a new issue that surfaced and have many passes on the tranny with before with no issues ,the only change is the longer shifter dont know if the quality of parts is the issue please chime thanks gmonde
Liked 1,937 Times in 437 Posts
You need to talk to Jimmy Bridges in Nashville TN.
Alan Roehrich 212A G/S |
Liked 510 Times in 117 Posts
I have probably 500 runs on my Jerico with no issues. Haven't heard anybody else with the same issues. I use the long shifter as well.
68 Chevy11 327 F/S Last edited by Bob Gullett; 06-01-2012 at 08:40 PM. |
#4 | |
Liked 1,443 Times in 302 Posts
James Schaechter 3163 STK |
#5 | |
I had debris between 3-4 slider and hub and broke this link. Bought new slider, hub and link. New link had more material around rectangular hole. New slider had also more clearance on hub, than old one. I have DR4 from 1999 and 10 finger dog rings.
Liked 20 Times in 12 Posts
We have broken two of them. The first one was only after about 20 runs on the new trans. We figured it was something freak. So we replaced the arm and bought a spare. One year later in valdosta we had the same thing happen, this time when we looked closer it looked like a casting problem. It snapped the arm off smooth with the side of the trans. The shifting linkage was dragging on the ground. We replaced the arm and have gone on with things. That has been several years and many runs ago. We to have a long shifter on it. I hope it was just a freak thing that happened to you. Good luck.
Liked 56 Times in 29 Posts
Did you carefully adjust the shifter stops?
Liked 57 Times in 14 Posts
You're not alone gmonde. We have been fighting this problem for 3 years now. It was bad enough at one time that we had to bring extra shift levers to the track just to make it through a race. After installing a new one (3/4), it would immediately start twisting and eventually break. When we removed the nut and slid the lever off, the internal hole would be rounded out. Lever was tight, but still moved around. We been through every test imaginable and haven't found a cause. These are the NASCAR hardened, long shift levers. Long shifter, as well. Everything is adjusted properly. Similar situation. We've run the same Jerico for YEARS without fail, then all of a sudden, BOOM, problems around every corner! The one variable you might check is that your bellhousing is indexed properly. If the transmission is misaligned, it will put too much stress on the main shaft and shift forks (and gears), causing the need to use too much force when shifting. We should be out testing in the next couple of weeks. If we figure something out, I'll post it here. Might be time for a Liberty.
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
Liked 2 Times in 2 Posts
I've broke one in the last 10 years. When mine broke my stop had loosened up and was not stopping the shifter, the slider/fork/arm was. After adjusting it on the bench with the cover off and seeing what its doing in there I've not had a problem since. But I believe the key is to set the stops with the cover off so you can see what you're doing. I set mine to where it leaves about .030" of play before "bottoming out" and let the dog ring suck the slider in the rest of the way. Haven't had a problem since. Also make sure your shifter rods are running as parallel as possible. Hope this helps
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 Last edited by 69Cobra; 06-04-2012 at 11:22 AM. |
