Old 07-16-2012, 03:55 AM   #1
navamotorsports
Default Footbrake Question
Ok question is. I have seen plenty of racers who one weekend show up at the race track and run electronics class. Then some other big dollar footbrake comes up and they run footbrake. I run electronics in my race car and the last time I raced a footbrake event it was a wreck with disconnecting the delay box. I run a biondo wizard box. Does anyone have a wiring set up or harness part number someone sales to make it easier. My biggest problem I had was because I run a transbrake getting into reverse was a challange of its own. Does anyone have any ideas pictures if any on how to make it easier. Thank You.
navamotorsports is offline   Reply With Quote
Old 07-16-2012, 10:26 AM   #2
Keith 944
Keith 944's Avatar
Default Re: Footbrake Question
i do this a lot. i used weather pack connectors on the delay box and everything else for that matter. i also use an electric shifter, takes about 2 min. to take that off. then the trans brake. i had a pro brake, had to push button to back up, went back to a "slow" brake, i just take the solenoid out and put the modulator back in. now its just a valve body. it takes me about 5-10 min. to change everything over. i also have to take out air bottle and replace my t-stop with a 2"spacer. a well thought out plan goes a long way. hope this helps
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Keith 944 is online now   Reply With Quote
