Old 07-19-2012, 02:32 AM   #11
Rory McNeil
Liked 1,104 Times in 302 Posts
Default Re: 72 Maverick
Originally Posted by treessavoy View Post
This is for you Maverick guys: Did Ford ever put a 4 speed behind it's 6cyl engines in a Mavericks?
JimR
No 4 speed available for the Maverick or Comet, 3 speed manual or automatic only. As for Maverick Stockers, Steve Horton from Washington State races a 73 Maverick 302 in R/SA, in fact he was at the Woodburn Oregon LODRS race last weekend. There have been at least 4 different 302 2 barrel Maverick & Comet Stockers in Div. 6 in the past few years.
NHRA 6390 STK
M/S 85 Mustang
Old 07-19-2012, 08:00 AM   #12
RobbieRacer
RobbieRacer's Avatar
Liked 118 Times in 41 Posts
Thanks guys, you have been a big help.
Thanks Mark. I will be talking to ya. I know you would be a BIG help.
Old 07-19-2012, 09:56 AM   #13
RJ Sledge
Liked 288 Times in 90 Posts
Ford put a 4 speed transmission in the later model 75-77(?) models, 4th gear was not a 1:1 drive ratio something like .85:1 overdrive, which was the going thing back then. The F100 and F150 had the same setup and those transmissions look like a 4 speed top loader but with different gear ratios. A lot of people are putting that setup in Cruisers and older Muscle cars. I have done 3 or 4. JPT turned me on th them, just getting harder to find good cores.
RJ
RJ Sledge is offline   Reply With Quote
Old 07-19-2012, 01:07 PM   #14
Rory McNeil
RJ
Ford put the 3 speed overdrive "Orion" toploader in Granadas and Monarchs, as well as light duty pickups and vans, but I`ve never heard of one in a Maverick.
NHRA 6390 STK
M/S 85 Mustang
Old 07-19-2012, 05:37 PM   #15
mtkawboy
Liked 54 Times in 18 Posts
Early Falcons , 63-65 era, had a Dagenham 4 speed behind the 170 6 cylinders. The OD 4 speed toploaders drove thru the cluster in overdrive and arent real strong. The weakest have bushings on the cluster & the better ones {used in vans }have needle bearings. Doesnt mean you have to run the original one though. I meant for street use
mtkawboy is offline   Reply With Quote
Old 07-19-2012, 05:44 PM   #16
David Lee
Liked 346 Times in 126 Posts
Here is the specs for all mavericks for all years
http://www.fordmaverick.com/yrtoyr.htm
Old 07-19-2012, 07:52 PM   #17
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
RJ
wouldn't that make 'em a 4speed?
btw, those od trans' are getting scarce to find parts for...
Old 07-20-2012, 08:47 AM   #18
Bobby Fazio
Bobby Fazio's Avatar
As someone said, the maverick will be tough in stock with the 2bbl which is why we went with Super Stock. We put a clone 289/210/210 motor in Jamie Schoenly's '72 Maverick here in D1 from spare parts lying around from my 289. It's not far under the index yet but it is a cool looking super stocker! I've never really looked into EFI combos, that's an idea..
Robbie is from Phoenix, so IHRA isn't a viable option..I'm sure he'd like to race at Firebird Nat's and Div's.
The 2 bbl 302 is okay here during the winter months anyway.
I would suggest building it as a good 9" tire car, but then use a low rated EFI combo for Super Stock, where you can use a transbrake.
There is a nice one in Div 1 done similarly.
Robbie, call or write if you want
602-769-0346
markyac@cox.net
'65 Mustang SS/L & L/SA
Old 07-20-2012, 10:15 AM   #19
BlueOval Ralph
Banned
How about a Maverick with a Boss 302 got GT? A 351 C would be fast but won't clear spring towers and get a good set of headers on it.
BlueOval Ralph is offline   Reply With Quote
