Could this be a 4.125 X 4.00 SBF ?
Banned
Liked 239 Times in 94 Posts
Isn't that what the 428 Windsor is now?
Liked 38 Times in 17 Posts
Is it rated at 275 HP?
Ed Wright 4156 SS/JA |
Liked 692 Times in 205 Posts
425 HP, same as the COPO Camaro. Same bore and stroke, the Ford has a longer rod. Wish I had either. Dyno
Liked 369 Times in 127 Posts
I was comparing the 2010 352 @ 285 hp vs. the 2013 363 @ 330 hp for the SS/GT classes.
The 2010 has a bore/stroke of 4.060 x 3.400 The 2013 has a bore/stoke of 4.125 x 3.400. Everything else looks the same. Using the .070 allowed overbore rule, a 2013 looks like it could also run as a 2010.
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Banned
Taking a 4.125 and a .060 over bore per the rule give you a 4.185 bore with a bore spacing of 4.380 this only leaves less than .200 between bores not a lot material for head gasket seal.
Liked 7 Times in 5 Posts
The 327 COPO has over a 2 to 1 rod ratio.
