#11 |
Liked 1,439 Times in 301 Posts
Yes. It is sticky and slippery at the same time.
James Schaechter 3163 STK |
#12 |
Liked 54 Times in 27 Posts
I use Torco RTF (racing trans. fluid) in all my manuals, car and truck.
#13 |
Liked 4,378 Times in 502 Posts
I was running the red line shock proof but jerico told us to take it out and use mobil-1 75/90 instead.
#14 |
I`ve also been using the Redline "light shock" in my Jerico (the blue stuff), I used to fill the trans to the fill plug, but I think I will try 1 quart next fluid change.
I also use Redlines "heavy shock" oil (the pink stuff), in my diff, as mentioned, this stuff clings like crazy! Earlier this year I pulled the diff cover after the car sat over the winter, and there was still oil clinging to the top of the case. And speaking of Jericos, am I the only guy who has troubles with gear oil seeping out the front? Its not the input shaft seal, i`m guessing it must be from the cluster shaft area. It doesn`t drip onto the ground, but always seems to have a drop sitting at the bottom of the scattershield.Any easy fix?
#15 | |
#16 |
Liked 520 Times in 132 Posts
They all leak. The one I have now is only a slow leak. My old one leaked so bad my son had to wipe it off in the staging lanes before the run. LOL
#17 |
Liked 6 Times in 2 Posts
Sounds like mine. I got an oversized bushng from Jerico and it's a lot better for now. They make several sizes of bushings so it's a known problem.
Dale Posnick |
#18 |
Liked 2 Times in 2 Posts
I run 1 quart of Royal Purple 75/90 and so far so good. The more you change it the better but I do want to try the redline products to see if there's a difference. Also, we just put some silicon on the front countershaft area it seems to help with the slow leak issue just clean the area really good with some brake clearer and it should be good.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#19 |
I got the HD case, top loader only, of A206 aluminum. No leaks.
