#31 | |
The 352 Stang is at 312 with a break of 10.43 ... D, E & F The 302 is at 325 with a break of 9.91
Chuck Beach 3340 STK |
#32 |
That is correct ... your 69 breaks at 10.47 with is a natural E car, my 68 breaks at 10.58 which is a natural F car .. but you already knew that ..
Chuck Beach 3340 STK Last edited by Chuck Beach; 08-21-2012 at 02:59 PM. |
#33 |
yes i forgot that the last hp hit took us out of g/sa. So we are an e/sa car now but we can barely get to max weight for e/sa plus there is already a dp in e/sa. With a 6'4" 280lb driver we cant get to d/sa. Lol
JOSEPH TEUTON 4044 STK,SS, |
#34 |
Liked 3,240 Times in 986 Posts
Well, at least that sounds somewhat more equal but what about the .400 tree out of the blue? Seems like unfair advantage for the 3 speed cars...plus the FS/S cars will run class using a pro tree and then eliminator using a full tree? I would claim foul on that one even if I had a trans brake and 3 speed...
#35 | ||
Liked 174 Times in 39 Posts
3207 D/SA, C/ED |
#36 |
Makes too much sense.
Ed Wright 4156 SS/JA |
#37 |
Why reduce the HP on 95% of the cars instead of raising the other 5%?[/QUOTE]
Because the 95% are the ones complaining. So fix the ones that complaing. =) Plus it's all done by excel so it's just as easy to do 95% as it is to do the 5%. Just like we are not asking to take away the three speeds from the CJ's and COPO's, we are asking to give us one!
#38 |
Liked 325 Times in 50 Posts
Your on-the-scene reporter has unraveled the problem. First it's fixed, Thanks NHRA. On May 9, a proposal for the Shootout was done and sent to the manufactureres. The weight was 3575, which was too much. After discussions, it was reduced to 3475 and posted on the tech site on June 18. When the adddition of the pro tree and a couple of other things were done, the weights from May 9 were picked up instead of June 18. Mystery solved. My blood pressure has now returned. Perhaps I overacted a bit, but I am pleased to announce it was handled poste haste (thats right now for you non-belivers). Now as far as the other age old discussions on here, they are like crabgrass, just won't go away. Next year we (and anyone else) have the three speed, so that is good. I had a good discussion with Glen Gray and Bruce Bachelder of NHRA as well as numerous e-mails with Pat in California. I ruffled some feathers for which I apologize. Maybe I was too involved in trying to get 5 cars to BG and Indy, and get over the martinis I was having when my son called and said we got 100 lbs added. The problem is fixed and the communication lines are wide open. Thanks.
Jeff Teuton 4022 STK |
#39 |
Liked 695 Times in 206 Posts
Hopkins ran in C/SA with his 13 Mustang/5.0 at BIR
#40 |
Liked 1,082 Times in 228 Posts
Good news for the Mopar camp! Maybe they'll get off the porch and play with the big dogs now???
Still disagree with the pro tree thing though. Makes no sense at all. How are they going to qualify? Run with the stockers on .5 full tree, then you have to run a .4 full tree for the class, then revert back to .5 full tree for eliminations? Total nonsense! Way overthought! ![]() Anyway, see you guys there! Brett Candies 4192 Stock/SS |
