Old 08-20-2012, 10:03 PM   #11
philbilly
philbilly's Avatar
Default Re: chevy 2 radiator
Thanks a bunch. I been wanting to try a nhra div. My car is close to legal I suppose.
philbilly is offline   Reply With Quote
Old 08-20-2012, 11:01 PM   #12
Originally Posted by philbilly View Post
James whats them measurments? why I got you one more question can the battery tray be reenforced with angle iron? will I be alright as long as its where its supposed to be?
Phil, Hope you can see this..It's fabricated aluminum. I didn't even paint it to hide it.
No one ever said anything to my...Four teardowns.
Just fix what you've got . It'll be fine.
Old 08-20-2012, 11:02 PM   #13
henrys57wagon
henrys57wagon's Avatar
If I remember correctly when you use threaded rod it has to be 3/8 dia, at least that was what I was told by a tech guy once when I had used 5/16.
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 08-21-2012, 05:26 AM   #14
james schaechter
Liked 1,439 Times in 301 Posts
Yes, that is correct! I should have added that.
James Schaechter 3163 STK
Old 08-21-2012, 07:13 AM   #15
philbilly
philbilly's Avatar
They battery will be fine. I dont like finding things out the hard way plus they are cheaper to fix at the shop. I am excited about attending my first NHRA div.
Old 08-21-2012, 02:31 PM   #16
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Originally Posted by Joe Schaechter View Post
The dimensions and a picture of the Chevy II radiator can be found and purchased at the following link:
http://www.usradiator.com/chevrolet-...-radiator.html
Do you think it's a bad idea to use a 2-row core, 6 cylinder radiator to save weight? Or will I run into cooling issues? My 327 block is filled, and I'm using a Meziere electric pump with electric fan....
Paul Merolla is online now   Reply With Quote
Old 08-21-2012, 05:18 PM   #17
Joe Schaechter
Joe Schaechter's Avatar
Liked 13 Times in 4 Posts
sent you a PM
Joe Schaechter 3168 STK
Joe Schaechter is offline   Reply With Quote
Old 08-21-2012, 09:34 PM   #18
philbilly
philbilly's Avatar
After a long day in the shop I got a big step in the direction I need to be going. I scored a rad. not in the best of shape but it holds water. battery box is done. new gear set in trans. only a couple more items to correct and I should be good to go.
