Liked 520 Times in 132 Posts
Is there really that much to gain by lightening a rear gear. I have to get a new ring and pinion(6.17 Dana 60) and figured while I'm at it. I don't have gun drilled axles or aluminum spool etc. Thanks.
Liked 3 Times in 1 Post
You won't see anything. However, if you do 10 of those things, it does somehow add up to an et reduction. Basic math doesn't apply here....
Wade |
Liked 280 Times in 139 Posts
I would look into cryo/ rem the gear set, might be worth a couple plus add some durability with a stick car. I don,t think there would be any visable gain to just machine the ring gear. gsa612
If it were me, I'd have the lightest ring gear, spool, wheels and slicks possible on a 283 car like yours.
Jeff Lee 7494 D/S '70 AMX |
90 % of the feedback I've gotten on this is its a waste of money I will see nothing. Now Jeff I can give you my address so you can send me a check to buy all the lightweight stuff you suggest LOL. I never heard back from you on that single disc 10" clutch??
Liked 1,034 Times in 368 Posts
We didn't see anything. I remember Joey Wilkes did everything. Gun drilled MW 40 spline and all. It slowed down...Ask him about it. It was kinda funny at the time, ( Even he was laughing)
Jeff Niceswanger 3740 SS |
Liked 166 Times in 46 Posts
I would say that it depends a lot on how much weight you can get off your ring gear.
I had one lightened in my 12 bolt and it only took off a pound, costed $200, and I didn't see a thing in et. Gears started howling quicker too. |
Liked 126 Times in 20 Posts
Can't hurt but won't help. Coating is far better way to spend money.
Tim Worner SS 1747 |
#9 | |
X2 And the rifle drilled axles with lightweight flanges and the carbon fiber driveshaft with billet alum ends and the titanium lug nuts. And all of the lightweight transmission components.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#10 | |
I'm of the opinion light-weight parts are what you want when you have a little engine like a 283. But I've never raced something like that so what do I know? I do know I saw a guy with a V/SA V-6 pick up around two tenths buy going to smaller / lighter wheels & tires and changing the rear gear to keep the same finish line RPM. I've seen other light-weight tricks performed on low HP / small engines and it always seems to help. If it were I, I would ask that those saying "did it, didn't work" what the combo they did it on was. Because a 350+ engine is entirely different than a 283 engine. And yes, I do understand it costs $$ and that's hard to come by. If your really tight, buy the gear and leave it alone. Put in a lighter spool though. And those are easy to find used.
