Old 08-26-2012, 09:35 PM   #1
STR001
Default Spring Recommendation Third Gen. Camaro
I have a 87 camaro that I am planning to run in the stock eliminator class (IHRA). Any recommendation on front springs and struts that work and are legal for this class? Thanks in advance.
STR001 is offline   Reply With Quote
Old 08-28-2012, 08:26 AM   #2
tj310
Default Re: Spring Recommendation Third Gen. Camaro
Stock V8 springs with 1/2 a coil cut off or V6 springs Lakewood struts. There is of course more exotic expensive stuff. ----Trevor
Old 08-28-2012, 10:25 PM   #3
STR001
Thanks for your response Trevor.
Old 09-01-2012, 08:44 PM   #4
jscamaro1
Liked 3 Times in 1 Post
I have the moroso trick front spring with a coil cut and the koni spa1's.
The moroso springs and the lakewood 90/10's would be a good start. If the money was there buying something ajustable would be best, rebuying all the time sucks.
jscamaro1 is offline   Reply With Quote
