Old 09-14-2012, 08:27 AM   #21
Todd Hoven
Guest
Posts: n/a
Default Re: Points for Qualifying and Records
Sounds like its time to build a better car, or become a better driver!
The statement that alot of people like to use " It's all just a bracket race" would change fast.
Originally Posted by fredjohnston View Post
Explain your "Bull!".
Let's say I've got a 2012 whatever and can qualify on the pole at every race. I can set the record a couple of times during the year. You've got a 1970 whatever and you qualify mid-pack every race and aren't fast enough to set any records. We both go the same amounts of rounds during the racing season. Who wins the Championship when points are awarded for qualifying and records?
Old 09-14-2012, 08:27 AM   #22
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
The person who spent the time, money, and ingenuity to prepare a better car. Everybody gets a trophy mentality doesn't apply in Drag Racing.
Pedigo Perf is offline   Reply With Quote
Old 09-14-2012, 08:31 AM   #23
David Barton
Sponsor
I agree 1000% with Todd. That's the biggest problem......its just a bracket race. If you want to just bracket race or if its not in your budget, they make other classes for you.
David Barton is offline   Reply With Quote
Old 09-14-2012, 08:54 AM   #24
B Parker
Liked 2,360 Times in 467 Posts
I really like the idea. You need to be careful how many points are awarded for qualifying. Lets face it it's not an even playing field out there. It would be nice if the AHFS would raise the 85 under average. There aren't many cars out there that can't run faster than that on an average. Barry
Old 09-14-2012, 09:02 AM   #25
Angelo DiTocco
Angelo DiTocco's Avatar
Liked 189 Times in 48 Posts
I think that is a great idea.
Originally Posted by Jeff Colvert View Post
Sounds great to me,I'm all in. Just cut off the AHFS when setting a record and racing will be fun again. Also when two cars in the same class run heads up for class cut off the AHFS.
Angelo DiTocco
'98 Firebird SS/HA
'98 Firebird B/SA
Angelo DiTocco is offline   Reply With Quote
Old 09-14-2012, 09:11 AM   #26
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
I like it !!!!!!!
Bob Bender 144 O/SA
Old 09-14-2012, 09:17 AM   #27
David Barton
Sponsor
Originally Posted by Alan Roehrich View Post
I don't think points for records would be too complicated. You'd need about 4 rules. (Feel free to point out anything you think I may have overlooked)
20 points for setting a national record.
No points for re-setting your own record.
Maximum of records in 3 classes per driver per year.
Records in only one car/engine combination per year.
With those rules, you get points for records, but you can't "game" the system by continually bumping the record by small amounts. You also can't switch cars/combinations and set a lot of records.
So it would work like this:
Driver X has a 1969 xxxx with a xxx/xxx engine, and an automatic transmission, for Stock Eliminator in 2013. It is a natural "A" car, so it can run "B" and "CC". So, driver X can set the record in CC/SA, A/SA, and B/SA, in the same car with the same combination. That lets driver X earn 60 points. If no one else sets any of those three records, driver X can only collect 60 points for setting records. If driver Y takes the A/SA record from driver X, then driver X can try to set the A/SA record again, if he succeeds, he earns another 20 points. Now, even if driver X sells his 1969 xxxx, and gets another car, or gets a ride in another car, he can only set records in CC/SA, A/SA, and B/SA. And he cannot reset his own records in the new car. So driver X can't get out of the 1969 xxxx, or swap engines or transmissions, then go set records in F/SA, G/SA, and H/SA, or any other class to gain points. That prevents anyone from spending money to buy more cars or get rides in more cars to set records.
And really, 20 points is not a lot of points for the effort and expense of setting a record, it is about the same as winning a round. Honestly, a record should be worth more than 20 points. But you have to be careful that 2-3 guys don't get in a little contest, since in theory those 2-3 guys could earn a lot of points bumping the record 0.05 taking it from each other, and making a record worth a lot of points could do that. In theory, if a record started out at 0.8 under, between 100 and 160 points could be paid for records before anyone even got instant HP. You'd get the record set 6-8 times in that scenario, at 20 points each time. Even making it pay 40-50 points to set the record, if two guys set it 6 times, that's 240-300 points each.
As much as I'd like to see it pay 40 points for a record, 40 points for #1 qualifier, and 40 points a round to win class, that's probably swinging the pendulum too far the other way.
You just proved my point, that is complicated. NHRA would read into about 3 sentences and say, "next".
Here is another problem with the record idea, but I have a solution. Since car counts in Division 1 are so high, they give you a limited amount of chances to actually set a record compared to other divisions. Each divisional director has there own view on how records should be set, and trust me Division 1 is the hardest by far.
Solution: Let anyone set a record at any time, its simple.
Old 09-14-2012, 09:29 AM   #28
fredjohnston
Liked 55 Times in 14 Posts
So if someone with an older car, as mentioned in my example earlier, and their combination is pretty much "maxed" out, then he/she should build a newer bogus combination if they want to chase points. Sounds logical to me!
fredjohnston is offline   Reply With Quote
Old 09-14-2012, 09:35 AM   #29
Billy Nees
Liked 7,925 Times in 1,760 Posts
Ya know Fred, I have a feeling that if I GAVE you a second under car (which I could but I won't), you wouldn't race for World Championship points anyway so what is YOUR point?
Billy Nees 1188 STK, SS
Old 09-14-2012, 09:39 AM   #30
MikeFicacci
Liked 19 Times in 2 Posts
Based on Fred Johnston's logic, we should basically get rid of all performance in the class and make it a bracket race. According to Fred's logic, we should probably get rid of heads up runs completely.
There are a few guys, especially on the west coast who run "maxed out" 69 Camaros 396/375 and can put in on the poll at just about any race that they want to.
Ultimately, I believe a points system for qualifying (and records) will help the AHFS work more quickly.
Mike Ficacci Stk 1010
MikeFicacci is offline   Reply With Quote
