Old 09-26-2012, 05:03 PM   #11
Greg Hill
Liked 279 Times in 68 Posts
Default Re: Converter Temp Effect on ET
Originally Posted by Dean Feiock View Post
Thanks for all the replys.
That is the same conclusion I had come to. Which is an indication that the converter is to tight for my every day routine.
The question becomes, do I run the transmission warmer all the time or do I get a looser converter?
Dean your car will be more consistent if you run it at the same temp every time. Trans temp is a variable that can be controlled. Get a gauge and a pan heater.
Greg Hill 4171 STK
Old 09-26-2012, 08:47 PM   #12
Adger Smith
Liked 880 Times in 311 Posts
I had a customer that had stock sprag go out in his tranny. He replaced it with one that had more elements. That was the only change he made. Before the change his car was deadly consistant. The change seemed to cause the ET to be "off" on the first pass. He figured out he had to warm it up to a higher temp to make it run the number without throwing out the first pass. He was running a hyd fluid and I've always thought it was more about the fluid than anything else.
Adger Smith (Former SS)
Old 09-27-2012, 07:34 AM   #13
MrWendy'sJr
Liked 25 Times in 1 Post
What type of trans temp gauge is better, electrical or mechanical? And full sweep vs short sweep?
MrWendy'sJr is offline   Reply With Quote
Old 09-27-2012, 07:55 PM   #14
Rob Petrie E395
Liked 216 Times in 77 Posts
Digital
Old 09-27-2012, 09:15 PM   #15
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
An electric gauge makes for easier transmission removal.
Old 09-28-2012, 08:54 AM   #16
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
I drilled and tapped trans above pan where temp gauge came down through top of case into fluid in pan, you could pull gauge probe and not lose fluid,also had plug could be put in if trans was going to be tilted while removed or transported.
Mike Taylor3601
Old 09-28-2012, 09:44 AM   #17
Jim Kaekel
Liked 535 Times in 110 Posts
I've got a mechanical trans. temperature gauge mounted in-line on the pressure side of the cooling lines. I've got one of those extruded aluminum coolers mounted underneath the right floor pan with a Auto Meter temperature manifold to accept the gauge. Works great and don't have to mess with it during trans. changes.
Jim Kaekel 3836 STK
