Liked 20 Times in 15 Posts
i have been looking at three brands of 'affordable price' rockers. lowest was the Comp Cams 'wide body' die cast. then the blue Scorpion brand then the original orange Harland Sharps.
i have a set of Cam Dynamics 'wide body' die or vacuum cast, which i have had/run for over 25 years and never had any trouble with. the ratio seems to be correct. however just because they look the same as the Comp Cams doesn't mean anything. i know a lot of circle track guys use the Scorpion brand. but they usually don't worry about the little things like the ratio being right on. and for that matter just because Sharp has been around for ever, does not mean they are right. so, help me with some input, on these three. thanks rod in AZ |
Liked 20 Times in 12 Posts
I have used Crane, Comp and Harland Sharp. For my stocker I have Harland Sharp. They have different models, fairly priced and pay contendency. Plus then will make the rocker in any incriment you wish. If your cams are over slightly then you can order a 1.48 or 1.49 rocker for example. That is who I recomend Harland Sharp. Just my .02.
Liked 1,015 Times in 278 Posts
Harland sharp is a great company to deal with. Their tech people are knowledgeable and gave me the impression that they were gonna help me anyway they could when i called with a question about my 10 year old rockers. I thought that was pretty good service.
Liked 18 Times in 12 Posts
"Real Race Cars Have Tailgates" |
Liked 138 Times in 51 Posts
I used Harland Sharp rockers on my bracket cars for many years. Worked great and took a lot of abuse. So I was more than happy to be able to use them again when they were allowed in IHRA Stock, and then NHRA followed suit.
Liked 482 Times in 159 Posts
Another vote for Harland Sharp ...
Liked 22 Times in 22 Posts
Howards, one of the best. Also, Harland Sharp, Scorpion, or Comp. The best stud girdle, Jomar, or the CNC'd one from Doug Herbert. Comp locks are the best.
don,t have one |
Liked 27 Times in 14 Posts
PRW has probably the best from the overseas stuff. Really depends on what kind of dough you wanna spend.
Feel free to call Rod 219-861-1214. |
Anybody here use or have used Yella Terra Rockers? Thoughts? Jim
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 NHRA D2 National Open Stock Champion 1982 NHRA D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() |
Liked 1,908 Times in 427 Posts
I have used the Yella Terra Platinum series. They're really good rockers.
I have used the PRW stainless rockers, but not the aluminum rockers. I've never used the die cast aluminum rockers, only extrusions. ARP makes the best locking adjusters. I've used Moroso, Crane, and Jomar stud girdles, with no problems. Others have been okay, but needed "tweaking".
Alan Roehrich 212A G/S |
