Old 06-21-2012, 08:37 PM   #31
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: jerico 3-4 shift arm lever issue
Brad Zaskowski has broken 3rd in his Jerico 5 times, he reported on his Facebook page, after he lost in the 5th round at Joliet, due to a broken third gear ( he has an in-car video of it breaking) Charlie Westcott told him not to burnout in 3rd, it is the least supported area of a Jerico 4-speed. Oh, and Charlie said to do burnouts in 4th gear.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 06-21-2012, 09:31 PM   #32
Jeff Lee
Jeff Lee's Avatar
I suspect those that have excessive base and / or counterweight are prone to breakage at any point on the track, even on the burnout. Of corse "excessive" is a matter of opinion, but the more pressures that are applied, the harder it is on everything.
Jeff Lee 7494 D/S '70 AMX
Old 06-21-2012, 09:48 PM   #33
TOSTO RACING
TOSTO RACING's Avatar
Liked 665 Times in 187 Posts
The only thing I've ever broke in a jerico is 3rd gear also. Must be the weak link on them. I also do a 3rd gear burnout. Its one hell of trans though, the torture we put them through lol.
5664 GHI/SA
1985 CAMARO RED H/SA --- FOR SALE
1985 CAMARO BLUE I/SA --- SALE PENDING ON BLUE CAMARO!
TOSTO RACING is offline   Reply With Quote
Old 06-22-2012, 12:36 PM   #34
acme383
If anyone has ever seen Charlie do his burnout, he shifts 1-4 in the box. check out any of his in car vids.
acme383 is offline   Reply With Quote
Old 06-22-2012, 01:00 PM   #35
69Cobra
Liked 2 Times in 2 Posts
You can do that with a clutchless.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 06-22-2012, 02:58 PM   #36
jeff g
He's also using the Jerico Hybrid 4 Speed... not the standard DR4/CL4 trans
jeff g is offline   Reply With Quote
Old 06-22-2012, 11:12 PM   #37
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
just an update on the ecentric breakage:: we had the trans apart to the point to change out the broken ecentric ,,after the second breakage total tear down was induced and the third gear bushing was destroyed dean cook found ,replaced third gear and three four shift syncros,,going down the track at this point gmonde
Old 11-04-2012, 08:40 AM   #38
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Originally Posted by Robert Simpson View Post
We have broken two of them. The first one was only after about 20 runs on the new trans. We figured it was something freak. So we replaced the arm and bought a spare. One year later in valdosta we had the same thing happen, this time when we looked closer it looked like a casting problem. It snapped the arm off smooth with the side of the trans. The shifting linkage was dragging on the ground. We replaced the arm and have gone on with things. That has been several years and many runs ago. We to have a long shifter on it. I hope it was just a freak thing that happened to you. Good luck.
This is exactly what happened to me yesterday, do you believe it was a casting problem?
'65 Mustang SS/L & L/SA
Old 11-04-2012, 09:01 AM   #39
james schaechter
Liked 1,443 Times in 302 Posts
Bobby, when you nave it apart, make sure that the shift fork didn't bend. It is something the happens mainly with the billet 3-4 fork. Also, on tnat fork, look at the machined groove that the arm goes in. If it has a dent in in, you will have an impossible time getting the shifter adjusted properly. Scott at Jerico says these can be repaired by welding it up and re machining the groove.
I had a couple that had done this after many years of service. It was impossible to get the correct gear engagement. It would be too deep in one dog and barely catching the other.
James Schaechter 3163 STK
Old 11-05-2012, 11:25 AM   #40
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: jerico 3-4 shift arm lever issue
Bobby, in our case yes it was a casting problem. You could see the impurity in the casting at point of failure. We called Jerico and told them what we saw. They were curious and we sent them the parts back for them to see. They said at the time they believed that it was a "batch" that could have been bad. We run a three speed (265ci). So we do our burnout in 2nd gear so to break the 3/4 arm was do to stress during the run not during our burn out. There is a definate problem in this area. We use the 1-2-4 gears. We also had the clutch very soft no counterweights. I am sure that a clutchless trans would be different, due to the design of the sliders. I think what Joe said is correct but in ours it had so little runs it was different.
Robert
Robert Simpson is offline   Reply With Quote
