Old 11-03-2012, 08:16 PM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,389 Times in 505 Posts
Default Anyone have a shift finger for Jerico?
If anyone is headed to Hagerstown tomorrow and has one I'd be very grateful. Thanks.
'65 Mustang SS/L & L/SA
Old 11-03-2012, 09:46 PM   #2
Stick Racing
Default Re: Anyone have a shift finger for Jerico?
Can you be a little more specific? I'm not familiar with 'finger'.
___________________________________
Andy Stone 1102 A/S 1112 SS/C
Stick Racing is offline   Reply With Quote
Old 11-03-2012, 09:56 PM   #3
Bobby Fazio
The piece going through the case that the shift linkage bolts to. I sheared the 3-4.
Old 11-03-2012, 11:50 PM   #4
Stick Racing
Ok, I personally do not have that piece. I do have a friend who may. I will check in the morning. I don't remember ever having broken one of those pieces.
________________________________________________
Old 11-04-2012, 11:23 AM   #5
Stick Racing
Sorry Bobby, can't seem to find one of those .
I'll see you at the track.
Old 11-04-2012, 01:45 PM   #6
Bobby Fazio
Ok thanks for trying Andy. Much appreciated.
Old 08-26-2013, 09:03 AM   #7
Bobby Fazio
I broke the same 3-4 shift finger again yesterday during second round. After this happened at the end of last year we ordered a couple and replaced them, this one only lasted 30 runs this year. Anyone else having this problem?
Old 08-26-2013, 09:09 AM   #8
james schaechter
Liked 1,443 Times in 302 Posts
I have not broken that, but have had a few friends that have. I wonder. Maybe check with Scott at Jerico and see if the heat treat or a engineering change ever took place.
They have a bunch of stress on them, especially those that use the taller shift handle and a lot of clutch.
James Schaechter 3163 STK
Old 08-26-2013, 09:38 AM   #9
buzzinhalfdozen
Liked 11 Times in 8 Posts
Only racers I've ever seen break them were using shifters without stops or the stops not correctly set. Have a freind with 4 speed jerico with hundreds of runs never broke it.
Joe Buchanan SS/BX 3117
Old 08-26-2013, 09:42 AM   #10
Run to Rund
Liked 56 Times in 29 Posts
I seem to remember a thread some months ago about a batch that were more prone to breakage. Scott at Jerico is the one to talk with. Also be sure that the shifter stops are carefully adjusted to lessen force on the finger and the fork.
