#391 | |
Liked 174 Times in 39 Posts
“For the little bit of time we had to test, and to go out there and win class, and do as well as we have done is a big statement for GM. It’s got a lot left. We haven’t had a lot of test time to get everything dialed in.” http://www.competitionplus.com/drag-...n-stock-action “This has been real good. We couldn’t be more pleased with how the car has been running,” Patterson said. “It’s still got the stock GM tune-up just like it came with when we picked it up two weeks ago. We’ve made some changes to the suspension and, so far, we couldn’t be happier.” http://www.competitionplus.com/drag-...ts-to-the-copo Final of CC/SA at Indy David Connolly 60': 1.306 330': 3.833 660': 5.995 MPH: 113.37 1000': 7.867 1320': 9.646 MPH: 112.01 Todd Patterson 60': 1.294 330': 3.819 660': 5.958 MPH: 116.26 1000': 7.815 1320': 9.540 MPH: 121.01 Looks to be a mid 9.30 against a low 9.40 run if they ran them out. "3:22 p.m. Weather conditions: air temperature 83 degrees, relative humidity 43 percent, barometer 29.16 inches, adjusted altitude 3,121 feet, track temperature 120 degrees." http://dragracecentral.com/DRCStory....r2012#indextop Is this enough backup for you?
3207 D/SA, C/ED Last edited by Andrew Hill; 12-16-2012 at 12:49 AM. |
#392 |
Liked 279 Times in 68 Posts
Andrew these guys are a bunch of dickheads including Charley. They couldn't play on a level playing field if their life depended on. It.
Greg Hill 4171 STK |
#393 | |
There is NO WAY that is the stock GM tune! Or engine,cam, gears, trans, vert, axles, driveshaft and the list goes on... They will not 1.3x 60' stock!!! The COPO cars are fast from chevy, but again NOTHING like Cazzette or Patterson. I'm not arguing, it's just apples and oranges comparing what comes off the floor and the cars your talking about. They are more like a BIW ground up build. More like 200k car.
Ross Gregory 5133 Stock,Super Stock 53 Top Dragster |
#394 | |
They had these cars for less than two weeks before Indy, not really enough time to do many in depth modifications, especially seeing as Cagnazzi was worrying about 2 pro stock cars as well.
3207 D/SA, C/ED |
#395 | |
Like I said BS that is the stock tune!
#396 | |
By all means, walk up to them and call them liars. Please, post your adventure to youtube so we can all enjoy it. The new COPO cars do not come off the showroom floor, and those are real COPO cars, I've seen them both. They are not body in white builds. Oh, and GM gave NHRA the rotating assembly weights, so your rotating mass goes out the window. Evidently you didn't see Mike testing the original COPO car right after the 2011 PRI Show. I was there when the guys at ATI gave him the converters for each engine.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 12-16-2012 at 01:51 AM. |
#397 | ||
These engines have not been apart (well they probably have been by now, but not then). Part of that shows how well they are built from the performance parts catalogs in the first place, but it also shows that there is absolutely no way in the world they should be rated the same as the old 427. Quote:
3207 D/SA, C/ED |
#398 |
Good god!
Not calling anyone a lier! Never mind carry on! By the way I own car 33 and will be racing next year. See you at the track.
#399 |
Yes, Ross, you are. Cagnazzi and Patterson said they were running the factory tune up, and you claim they were not. That is pretty damned clear, you claim they are stating things that are not true. Pretty much how Webster defines the word "lie", or the word "liar".
Alan Roehrich 212A G/S |
#400 | |
Here is the video hell it even says tuned by Brian Macy... Turn up the sound. That car has a three speed and a lose vert. [ame="http://www.youtube.com/watch?v=X91mgz6b7AU&feature=youtube_gdata_player"]2012 COPO Camaro Testing - Victor Cagnazzi Racing, Dave Connolly and Brian Macy - YouTube[/ame]
