Old 12-17-2012, 02:45 PM   #11
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Need help
Vic ,you have to hold the stop side of the switch for about 10 seconds and then release it , then it will flash the secondary code.
Old 12-17-2012, 03:49 PM   #12
vic guilmino
Liked 56 Times in 21 Posts
Tom
I hold it down for 30 seconds
Vic Guilmino 1129 STK
Old 12-17-2012, 09:18 PM   #13
Don Himes
Vic, when was the last time you changed the air filter on the Gen.? Something that simple caused mine to not start. Oh, BTW, the gen set code lite should blink, then pause and blink again. Read these as separate codes. Hope this helps........Don
Don Himes 2075
Don Himes is offline   Reply With Quote
Old 12-17-2012, 10:19 PM   #14
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I had all kinds of problems with my Onan, it would run fine until it had run for a while, and was shut off. When trying to restart it would throw a code 34, and would have to get completely cold before it would restart. Turned out to be a weak fuel pump. Replaced fuel pump and it always starts now. Replaced fuel filters, fuel line, module. Good luck it can be a real pain.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 12-17-2012, 10:54 PM   #15
vic guilmino
The onan will turn over
You hold it in the start it flashes 3
You hold in the stop the light comes on flashes 2 times then on the 3rd it stays on
Old 12-18-2012, 12:17 AM   #16
Tom Goldman
Vic, here's a link to the manual for your Onan.
Page 25 on up is code reading and definitions with trouble shooting.
Your code could be code 11 or 21.
http://www.cumminsonan.com/www/pdf/manuals/981-0161.pdf
Mabe try sending a PM to Rich Bieble, he's been working on Onans forever.
Tom
