Liked 71 Times in 23 Posts
Who makes the best rear coil springs for 1986 camaro. This is for a bracket car, set up like a stocker?
Ride height cannot be low because of tire clearance. Thanks Monte.
Monte Howard 3209 STK, 3208 SS Last edited by Monte Howard; 12-19-2012 at 09:50 PM. Reason: Spelling |
Monte, I would figure out what rate you need and go to the Moog catalog and reference the spec section to see what fits your need the best.
Softest you can find that will hold the car up.
Ed Wright 4156 SS/JA |
Liked 693 Times in 205 Posts
Eibach used to make rear drag springs, check them. Dyno
We put some Eibach springs on Bob Bullocks car and they worked good, but I don't think they make them anymore.
Al I will check out Moog. Ed, what do you think would be a good spring rate to start with 200?
Monte Howard 3209 STK, 3208 SS |
Liked 27 Times in 14 Posts
Monte,
Email Dad. monymkrssla@aol.com We should have something on the shelf I suspect with everything we stock. |
