#11 |
Liked 12 Times in 12 Posts
#12 |
Liked 359 Times in 135 Posts
Didn't Dave Kempton have a 4 door version?
#13 |
Liked 10 Times in 10 Posts
It didn't take long for some of the Mopar Guys to figure out, rather
than beat yourself up running in A/SA with a Plymouth Sport Fury or Dart Model 440 361/305 HP in 1962. Switch over to a Station Wagon (6-Passenger) (#3580 lbs.), and clean up in B/SA in 1962. 1963 thru 1965, The 361/305 HP 'Mopar Wagons' were classed in D/SA, and were potent runners, and regular Class Winners. Last edited by Paul Ceasrine; 12-15-2012 at 10:57 AM. |
#14 |
I came across this article on a '62 Dodge station wagon called the 'Tennessee Hustler'...does anyone here remember this one.
![]() http://www.1962to1965mopar.ornocar.com/zornig62.html . Last edited by Hemi Moose; 12-23-2012 at 04:05 PM. |
#15 |
Here's an oldie of a '62 Plymouth Sport Fury...
#16 |
Paul. would you have anymore info on these Golden Lion 361's, I seem to remember that they came in the full size models...
#17 |
Here's one of another '62 Dodge station wagon...anyone know the history on this one.
#18 | |
Liked 66 Times in 30 Posts
http://www.competitionplus.com/2005_...e_fulcher.html |
#19 | |
Liked 48 Times in 44 Posts
The 383/343-8v (parts counter or in-the-trunk combo) had a solid cam, looks like it may have been the same as the 413/380hp 300H cam? When I look in the NHRA Blueprint files, a lot of the 1960-63 era Mopars have a hyd cam, eg lift .430 .430, and then an "option" for a solid cam, eg gross lift .444 .458. The NHRA Blueprint for 1962 361/305hp shows .444 .456 (gross?) lift so it makes me think that is the solid cam. Did the 1962 361/305hp run this same (solid) cam or have an option for that solid cam? That might explain why it ran so good. Mopars are more confusing than Pontiacs sometimes. |
#20 |
Liked 274 Times in 143 Posts
My Grandfather ran the 361/305 in a couple '62 Dodge's from '66-69. It was a hydraulic cam, with a single point distributor.
The 383/343 is a solid cam combination. |
