Old 01-07-2013, 08:40 PM   #31
B Parker
Liked 2,343 Times in 465 Posts
Default Re: Need Gear Recommendation
Joe No never shifted that low and I'm not going to. Things have changed a lot since even the 90's. I would also have to ask Glen if he had a play back tack. I refer back to Mr Beards committ on what we really are shifting at without a play back tack . That was the first thing I learned when I put a play back in my car years ago. I was off at least 300 rpms on the 1st to 2nd shift. With the way I had the big block set up I would have to shift about 500 rpms ahead 1st to 2nd.
Old 01-08-2013, 03:05 AM   #32
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Question Re: Need Gear Recommendation
Dave Noll, EF/S ,?/SA 6526
Old 01-09-2013, 04:06 PM   #33
Originally Posted by Dave Noll View Post
Question since it kinda came up here. Is the difference between a 9" 4800 stall $350.00 E-bay special & a good high dollar convertor, the custom design billet stator ? And with that stator does "Flash speed" go up as well as torque multiplication ?
No easy answers here,Dave
The 9" GM is a common core from the 80's ...therefore they can be built a lot cheaper...That's why you see those deals out there.
Certain 9 " combos are capable of multiplying more torque than an 8", but you've really got to know what you're doing to match the performance throughout the entire quarter mile.
The 8" stuff are re-pops based on the old Opel design, so they cost more going in.
You really don't need a custom designed billet or fabbed stator for a Stocker.
Those are more for the high hp apps. or high RPM Comp style 7".
The RPM and stall may go up, but not necessarily the torque multiplication.
Old 01-09-2013, 04:20 PM   #34
B Parker
Hey Mark did you get your phone charger? Glad you answered his question. I looked at it and said it's the same as getting a pair of street header on ebay for 300. Or spending more money on a good set of race headers. You get what you pay for. ( Most of the time) Why buy parts twice. Buy the best only once and you won't be sorry. A cheap convertor 350. A good convertor 850. Loosing heads up in the third round because you saved 500 on a convertor PRICE LESS!!
Old 01-09-2013, 04:45 PM   #35
I did. Thanks again.
Hope to see you and that bad a** Corvette soon . Very impressive.
Old 01-09-2013, 05:31 PM   #36
Dave Noll
Dave Noll's Avatar
Old 01-09-2013, 07:56 PM   #37
Liked 1,880 Times in 422 Posts
An 8" ATI converter is an all new converter, it is not built on used cores. The stator is not billet, but it is a new casting, ATI bought the original tooling, and then changed the design to remove the sharp corner between the stator fin and the ID and OD of the stator. The ATI stator has fillet radius joints, to prevent fin breakage. The advantage to the ATI stator is the shape of the fins, which are curved and shaped like an aircraft wing or propellor blade.
Old 01-09-2013, 09:47 PM   #38
B Parker
Mark hope to see you this year at Indy. And hopefully I will be able to make a full pass by then. Dave if 350 is all you can spend on a convertor you may want to ask on this board if anyone has a good used 8" that they will sell you. This can be an expensive game. It's just cheaper to spend what money your going to once. Barry
Old 01-10-2013, 05:49 PM   #39
Dave Noll
Dave Noll's Avatar
Barry & Alan, Thanks as well. Good info & advice.
Old 01-10-2013, 06:42 PM   #40
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Lonnie
THE BEST THING TO DO IS TALK TO GARY PARKER.
HE DA MAN WITH THAT YEAR CAMARO......
BEST THING TO DO BEFORE SPENDING A TON OF $$$$$$.
"Pistol" Pete Dutko
