#41 |
Thank You Pete I called him this week, we are already going to do a leak down test this weekend, I just want to find something and fix it.
#42 |
Liked 19 Times in 4 Posts
Lonnie it is all basic math as for what you trying to figure out. Using your 12.80 x 102mph =1305ft Just look at all the national record holding ets they are geared for 1270 to 1310.Its math has not changed since the Egyptians.
#43 | |
Liked 7 Times in 7 Posts
(not trying to steal the thread guys) |
#44 | |
Leak down all cylinders 8 to 10 % Ok. jacked the rear of the vehicle up warmed up the rear end and could barely move the tire. Replaced brake shoes and springs, had the drums turned, Warmed rear end up again, like night and day. can turn the wheel with one hand. Going to test again 1/25 at Famosa. Thank You again everyone. I will keep you posted. |
#45 |
Awesome... sounds like you may have found a big part of your problem...
Cant wait to hear how it goes!
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#46 |
Liked 3 Times in 1 Post
Lonnie Cox, After you fixed your brakes did you run your car,
if so how did it come out? |
#47 |
The converter flash is 4900 is that enough?
#48 |
#49 |
Mark how much should it flash, we were standing still in 3rd gear ,mat the throttle and 4900 max.
#50 |
Lonnie,check your pm,I left you an update to my last message.
