Old 01-29-2013, 12:47 AM   #21
Bob Emery
Default Re: under the index for under a grand?
Michael, PM sent....
Bob Emery is offline   Reply With Quote
Old 01-29-2013, 12:28 PM   #22
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Got it, and replied.... although you should post it on the board for everyone. Good topic.
Old 01-29-2013, 11:12 PM   #23
Bob Emery
Michael, thank you...here's my question and his very quick answer:
Originally Posted by Michael Beard
Originally Posted by Bob Emery
Michael,
I hope you don't mind the PM, but a thought came to mind..... if I street and race it, how do I manage race vs. street fuel as far as a fuel check goes? Would I have to purge the stock from the system every time, and if so, how would I go about that to keep the race fuel within specs? I seem to remember reading that regular street fuel won't pass fuel check...
It certainly sounds like a combination that would be a great starting point!
Thank you for your insight, greatly appreciated!
Bob Emery
Yes, you'd have to completely drain the tank, the probably put just a tiny bit of the new fuel in and run it out to make sure the lines don't have any of the old fuel in it, then put what you need in. Race fuel will kill a catalytic converter. Could it be done? Sure... it'd just be a major pain.
Jeremy Preston in FL actually does this with his Corvette. Street-legal Stocker! He's won one in both NHRA and IHRA I believe.
Old 01-30-2013, 12:14 AM   #24
Dennis P Chapman
Liked 53 Times in 25 Posts
You can use unleaded race fuel but cost a lot to run on the street.
Dennis P Chapman 1904 STK
Old 01-30-2013, 11:47 AM   #25
69Cobra
Liked 2 Times in 2 Posts
To bad E85 isn't a legal fuel but I guess the local convenient store pump specs still wouldn't be consistent enough to pass fuel check. The other thing you might think about is putting a separate 5 gal fuel cell in just for spec fuel with a three way valve on it to switch between fuel tanks. You would still waste some getting the old fuel out of the lines but you wouldn't have to mess with draining the street stuff out.
I'm seriously considering seeing what I can do to the wifes old daily driver. Its a 97 Grand Prix 3.8 supercharged. Natural AF car which is a 13.85 index. Not sure what it would take to get it there. Hmmmmm
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 01-30-2013, 12:27 PM   #26
art leong
I did it with my acclaim/spirit. Drove it from NYC to Orlando ran in FF/SA qualified number 1 , drove to Gainesville dropped the car 4 classes CF/SA qualified 9 or 10. Then drove home.
This was with a stock fuel tank. Just pumped out the street gas, put in 1/2 gallon of race gas. Pumped that out 2 times. Then put 10 gallons of race gas in.
Art Leong 2095 SS
Old 01-30-2013, 01:14 PM   #27
Robert Simpson
Liked 20 Times in 12 Posts
Talking Re: under the index for under a grand?
Art,
I remember you did that 1 year in Orlando, set the record, tore it down, Passed (I was one who helped check it), I believe you found something broke in the engine, went to the salvage yard? Got the part, put it back together and then drove back to NY. I beleve you even had a mini roll up blind that had you class and number on it? You would just put it on the window and that was that.....Loved watching you do that...Good times
Robert Simpson is offline   Reply With Quote
