Old 01-31-2013, 07:48 PM   #1
SC1229
Default Whats It Worth
1962 Chevrolet 327 out of an impala ss. looks to be untouched .
SC1229 is offline   Reply With Quote
Old 02-01-2013, 08:54 AM   #2
tj310
Default Re: Whats It Worth
When your trying to sell it you have to say it came out of a Vette. ---Trevor
Old 02-01-2013, 09:49 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 312 Times in 105 Posts
Also that it does'nt use a drop of oil, or if you have'nt ran it since you've owned it you could say it has'nt used a drop of oil since I've owned it.LOL
Now on serious side I don't really know a # to tell you.
Mike Taylor 3601
Mike Taylor 3601 is online now   Reply With Quote
Old 02-01-2013, 10:01 AM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
If it is a 300 hp version, it could have 461X heads which would up the ante a bit. Hemmings is a good place to sell such stuff.
Old 02-01-2013, 10:04 AM   #5
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Whats It Worth
What version of 327 is it? A 250 horse has a 4 jet carb, the skinny intake, #520 or #896 heads,(power packs with the little pyramid), and exhaust manifolds with a 2" outlet. The 327 has an AFB, the wide intake( #459) . and a set if 461 camel hump heads .They also had the 2 1/2" exhaust pipes like a 409 had. Should bring a few hundred bucks at least. Good find!
Old 02-01-2013, 03:47 PM   #6
SC1229
The numbers from the deck are,CEN9809 The Heads 896, Block Is 3989612 . I'm Not trying to sell the Engine, Just Trying to Figure out If I should Keep it Around. Thanks For The Replys
Old 02-01-2013, 04:09 PM   #7
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: Whats It Worth
Those things are getting hard to find, I'd hang onto it.
Jim Cimarolli is offline   Reply With Quote
Old 02-01-2013, 09:58 PM   #8
Greg Reimer 7376
If that's an original never rebuilt complete take out engine, it's probably worth around $650-1000 depending on condition, but only if it still has an original standard block and crank. Those are almost made of unobtanium.Also, with an 896 head, it's a 250 horse. Might be a good Stock Eliminator piece with a #459 intake and a 4 jet.What happened to the 62 Chevy?
Old 02-02-2013, 01:27 AM   #9
Michael Kilduff
Last year I bought a complete 1968 327-250hp engine that had been pulled out of a wrecked '68 Caprice 20 years ago. It was from the air cleaner to the pan, flex plate to the fan, for $250.00.
IHRA STK 932 O/SA
Michael Kilduff is offline   Reply With Quote
Old 02-02-2013, 01:01 PM   #10
SC1229
62 Impala is alive and well . the owner wanted a crate motor with more power.
